Would like to see the strongest stock/built355/383/396, H/C LT1/LT4 cars out there!!
If you could please post up what motor "displacement", heads and cam combos,trannys,bolt-ons and power adders your running and what kind of power your making and what your running at the track. I would like to see everyday peoples daily driver combos to see what is happening in the LT1 world. I would also like to see a lot of Lloyd Ellietts work that is out their.
Well, if you post this again in a month I can give you a few answers...
My combo has changed (was a 396 cubic motor), due to rust issues awaiting my heads from AFR then from LLoyd. Our fault...sometimes even a sealed engine with oiled down cylinders can go bad...live and learn..Anyways, my Lloyd ported AFR 210's will be cranking on a new combo soon.
Jimbob...No more 396
well I was trapping 122-124 on a stock bottom end
224/230 112lsa 1.6 rollers Long tubes and a cutoutwith a 100 shot
6 speed with spec 3 and street tires and stock 10 bolt (3.42s)
I now have a 383 11:5:1 compression
eagle 4340 crank and rods, diamond pistons
236/245 114lsa .569/.580
mcleod street twin
ford 9 with 3.90s
But aint running right yet so Ill let you know when it is
mcleod street twin
ford 9 with 3.90s
Originally Posted by N20Dave
Mines nothing special, Just a little ol' 396 with set of used redneck heads . It only makes about 700 on the motor right now.
just messin
Shout me a pm with questions and I'll se what I can answer.
Back to original thread, this car actually started out dead stock and was a hc car that made 353 at the wheels and went 12.96 @ 110. That gives you an idea for your poll. The heads were ported byme and were nothing special maybe 230cfm at that.
I'm the world's record holder for ET with the stock A.I.R. system still fully on the car.
Ran a 11.90 at 115 with my 355 LT1. Just swapped in a Pro-Fab K member, and removed the pesky AIR system. So, with 50 pounds off the front, I'm ready to go back to the track soon.
With this extremely hot weather, I'm not expecting any gain, however.
Originally Posted by z28racerlt1
N/A 355 w/ LT1 heads and a hyd roller cam.
Turbo 400 w/ brake.
Best so far this year. 10.930 @ 122
1.448 60'
IT WILL GO FASTER THIS YEAR. Looking for 10.70's.
Ken
Turbo 400 w/ brake.
1.448 60'
Ken
Originally Posted by METALBEAST
What heads are you running?
Originally Posted by ou812/z28
check my sigs. as of now i think that i have the fastest lt-1 with stock pcm and harness. that is n/a.
