Problems, Problems, and More Problems! Please Help!
Old Jun 24, 2005 | 11:14 AM
red95ssclone's Avatar
Default Problems, Problems, and More Problems! Help!
The other day I pulled up to a stoplight and looked down to see that my car was almost at 260. A hose blew and steam came out of the hood, etc etc.
I get it back to the house to find a broken hose,(the hose that goes to the heater core from the water pump). I replaced it and flushed the system. I pour new coolant into it and notice that it is just coming back out from behind the water pump.
I pull the water pump and see that it is toast. I replace the water pump and again put new coolant in it. I made sure to fill the water pump up before installing the thermostat.
I go to start the car and all it does is turn over(sounds as if there is no spark, not 100% sure though). After about 3 or 4 seconds i let off the key, it sputters like it kinda wants to start, and then dies. I pull the intake elbow to see white smoke drifting out of it and a lil out of the throttle body.
I made an attempt to keep coolant off of the opti. But as you know that kinda damn hard when the thing is right under the water pump.
Whats goin on here? Thanks alot for your help, its greatly appreciated.
Old Jun 24, 2005 | 02:54 PM
Fixed! Im 90% sure that i got to much water on the opti. I let it dry out for a day and it just started right up. Bleed all of the air out and now it run's fine. Thank god
