Checking OBD I trouble codes with a paper clip
Old Jun 28, 2005 | 10:27 AM
contraststriker's Avatar
Default Checking OBD I trouble codes with a paper clip
So since my 95 is OBD I with the OBD II style connector, I need to know which pins to connect with a paper clip so I can read trouble codes? I'm pretty sure the SES light just blinks numbers and tells you codes on all pre-OBD II vehicles. So which is the diagnostic pin and which is the ground on a 16-pin interface?
Old Jun 28, 2005 | 10:45 AM
HBHRacing's Avatar
you can not flash DTC's on a 95.
Old Jun 28, 2005 | 10:57 AM
But I suppose you can on a 94? Damn my year!
Old Jun 28, 2005 | 11:29 AM
HBHRacing's Avatar
nope. not on 94 either. Early 93's and under and the only ones. Your stuck needing someone with a good program or scanner to read codes for you.
Old Jun 28, 2005 | 11:50 AM
Well I've got the 16 pin-to-USB cable so maybe I'll just try to find a free scanner program...any ideas?
Old Jun 28, 2005 | 12:46 PM
Brett95z's Avatar
TTS Datamaster.... search for it and download the free version.
