hesitation, misfire & backfiring
Old Jun 30, 2005 | 08:39 AM
pops z28's Avatar
Unhappy hesitation, misfire & backfiring
I'm new to the 4th gens, just bought a 94 z28 4 weeks ago with 77000 miles. Intake elbow was wore out replaced with trick flow, other than that the car is stock as far as I know.
I have noticed a slight hesitation at easy take offs, and at wot it takes off then starts to bog down and starts poping, like its back firing. I am going to try and change the plugs and wires to see if that helps. Does this sound like a good place to start. Where else should I look
Any info. HELP THE NEWBY THANKS
Old Jun 30, 2005 | 08:45 AM
HBHRacing's Avatar
I would start by runing a fuel pressure test.
Old Jun 30, 2005 | 11:32 AM
BichizleMyNizle's Avatar
sounds like what was my problem exactly... might be ur opti-spark read my post https://ls1tech.com/forums/lt1-lt4-modifications/343368-fuel-spark-cut-off-2500-3000-rpm-wot-help.html
Old Jun 30, 2005 | 11:49 AM
BGImportkiller's Avatar
My vote is for the opti.
Old Jun 30, 2005 | 12:42 PM
pops z28's Avatar
thanks guys, I thought I might be on the right track. I also noticed that it seems to bounce off the rev limiter a few times, I think from 3rd to 4th gear then it shifts. Could this be the clutch packs slipping. It has an A4 tranny.
