Cam for stock heads
Old Jul 5, 2005 | 09:49 PM
Smo's04Gto's Avatar
Hydraulic roller design
I:234
E:242
I:539"
E:558
Zero/Zero
112
12370847 Hydraulic Roller Design
This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 234/242; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 539/558. Valve lash is zero/zero and lobe centerline is 112 degrees.
http://www.gmpartsdirect.com/results.cfm
