AN fittings are installed
Old Jul 6, 2005 | 08:25 PM
monster7's Avatar
Default AN fittings are installed
finally got the fittings welding on today they are -8 AN
im so close now i can taste it
ill post pics later i cant get them to upload right now for some dumb reason
Old Jul 6, 2005 | 08:36 PM
monster7's Avatar
here the pics
Old Jul 7, 2005 | 02:42 PM
z28boysteve's Avatar
That's a beutifull LT1 there, hey what transmission is that in the back a TH400 with an f-body tailshaft housing?
Old Jul 7, 2005 | 04:05 PM
monster7's Avatar
the tranny is a 700r4 sittin in the back ground its not goin behind this engine
i have a built 4l60e that will soon be on the way here.
Old Jul 7, 2005 | 04:06 PM
monster7's Avatar
here is another pic from the front
Old Jul 7, 2005 | 04:23 PM
where did you get that alternator bracket! I need one just like that... also the CSI pump motor, I know they make them but all I can find to buy is meziere, and my buddies meziere went out prematurely causing a cracked block.
Old Jul 7, 2005 | 05:38 PM
monster7's Avatar
i bought the pump from a forum member over on cz28
the bracket is a more performance bracket which i dunno if they make them still
im talkin to a guy same one that put the fittings on for me and thinkin about having him make a couple of them if i do ill let you know
bad part is i dunno if i can use the bracket in my sonoma because the frame rails are to close together i think ill see when i get to that point.
Old Jul 7, 2005 | 10:48 PM
DMH Fabrication's Avatar
fuel rails look good. did you powdercoat the intake or is it painted?
Old Jul 7, 2005 | 10:53 PM
monster7's Avatar
its powder coated along with the t stat housing, steam pipe, alt pulley and the pcv hard line
Old Jul 8, 2005 | 01:04 AM
SRZ's Avatar
SRZ
Fuel rails are sweet! Care to make any more and how much? What advantages do those have over the stk line? Are you able to push more fuel through the rails now? I don't know so I'm asking. Again sweet job!
Old Jul 8, 2005 | 01:13 AM
monster7's Avatar
im not duplicating the rails what im thinkin about having made is the alternator mount that z28boysteve asked about
the rails will move a bit more fuel now as i can run -8 lines to them which is what my fuel system will be plumbed with
as far as putting these on an f body would require alot of work probably because the stock regulator is on the rails i have an aeromotive pump and regulator so this was the easy way for me to setup my fuel system
