Injector fix
Old Jul 11, 2005 | 07:08 PM
Ari G's Avatar
Default Injector fix
Has anyone tryed to put 36#lb Bosch injectors 0280155811 in an LT1?I´m trying to but they are about 0.3mm to short,What could i do?i´m thinking about lowering the fuel rails by taking some material off the bolt passage where the rail rests on????
Old Jul 11, 2005 | 09:42 PM
dhdenney's Avatar
I've never heard of such a problem....
Old Jul 12, 2005 | 11:15 AM
Ari G's Avatar
Spec on the injectors
Fitment: Standard Bosch-style rectangle connector with two flat electrical prongs
Resistance: 12.4 Ohms
Standard 14mm o-rings
Overall length: 73mm (3")
O-ring to O-ring: 65mm
Diameter: 20mm
Fits Z06,LS1.Mustang,T-bird og Lightning
Old Jul 12, 2005 | 04:25 PM
Pampered-Z's Avatar
Do the injectors have two slots in the top where the retaining clip slides in? If so you use the top slot
Old Jul 12, 2005 | 07:38 PM
Ari G's Avatar
You don´t have to use the clips,they were only put there to hold the injectors while they were transported to the Gm Factory
i do not use them,they do not fit
