im screwed.... BAD!!!
If its in the crank really tight about all you can do is drill a hole in it, then get an easy out and hope it comes out.
When i broke an ARP head bolt, after i pulled the head off i unscrewed the broken stub by hand.
I also busted a grade 8 bolt while installing my balancer hub and then ended up getting a bolt with the wrong threads to replace it so it stripped my crank. I was able to back the first bolt out because it broke right at the end of the crank and was not tight in the hole.
To make a long story short I drilled out the crank, installed a heli-coil, put eveything together and have not had any problems since.
Good luck
ZcarGuy
