Cam Bearings
Old Jul 19, 2005 | 07:31 PM
resurrectedz28's Avatar
Default Cam Bearings
Ok my engine has 144k on it (93 lt1), and i have a cam i want to put in, but havent because i don't have the time to do anything if it were to spin a bearing. My question is (bear in mind i know its not the best/smartest thing to do) if I were to drop the engine and replace all the cam bearings and then put in the cam, what kind of problems would i run into? Would i still run the same risk because i did not replace the other bearings? I think from most things ive read failure happens due to a spun rod bearing because it didn't get enough oil since a cam bearing was on its way out, but i don't have any personal experience??? Thanks in advance
Old Jul 20, 2005 | 06:32 PM
Anyone?? Or is just stupied to not replace all the bearings (i don't want to rebuild right now.)
Old Jul 20, 2005 | 08:01 PM
97MysticZ's Avatar
What's a Sticky?
If you really want to go through all that trouble, I'd replace everything. Or, just go ahead and put the cam in.....it will either last a while, or worse case scenario you will spin a bearing or something, but at least you tried before you tore it all apart for nothing- thats what I would do if i was on a tight budget like it sounds like you are.
