o2 sim problem
Old Jul 22, 2005 | 12:54 PM
steves97z28's Avatar
Default o2 sim problem
i cant seem to get the sim on bank 2 to work. i have replaced it once after getting a no activity code. and still no luck. what else could cause it not to be working?
Old Jul 22, 2005 | 12:55 PM
BlackScreaminMachine's Avatar
Internet Mechanic
broken or burnt wire??
Old Jul 22, 2005 | 12:59 PM
i didnt see any but i need to look better on the harness side, i hope not, if it was how would i go about fixing that?
Old Jul 22, 2005 | 01:14 PM
HBHRacing's Avatar
unhook the 02's and pull the entire harnnes up twords you from the top. Remove the sleave and see if you can find melted or burnt wires. Fix as needed. Reroute and cover in a better heat sheild then try again. The chances of 2 bad simms are pretty nill.
