fuel system upgrades for turbo
Old Jul 28, 2005 | 05:52 PM
steves97z28's Avatar
Default fuel system upgrades for turbo
what are some good fuel system upgrades?ill be adding a sts to my stock motor and i know it might now last long but a new motor is in the works so i need the fuel system to be good enough for when the new motor comes. i was thinkin of getting the racetronics kit i think its called.
Old Jul 28, 2005 | 06:10 PM
Vendetta's Avatar
depends on how much boost you run, but a 10.5:1 compression and boost dont mix. I'd upgrade the pump and the injectors and get a good dyno tune.
Old Jul 28, 2005 | 06:32 PM
thats the plan, i will start gettin parts for a forged 355 asap, i just got the kit today and i dont think i can sit here looking at the kit and not put it on
Old Jul 28, 2005 | 08:48 PM
96capricemgr's Avatar
The Racetronix kit an a good set of injectors be they the ones Racetronix sells or the SVOs should be all the fuel system work you need unless you get really wild with the turbo later on.
Old Jul 29, 2005 | 01:33 AM
Vendetta's Avatar
I used 42 lb/hr SVOs with a Vortech Inline pump on 10 psi and fuel problems were one of the few headaches I didn't have.
Old Jul 29, 2005 | 08:53 AM
cool looks like that is what ill do, boost will be set at 5psi with a FMIC from the get go that way when the new motor goes in i can turn it up and get a little crazy with it.
Old Jul 29, 2005 | 10:25 AM
z28boysteve's Avatar
5psi on 10.5:1 with the right tuning, the motor will last forever, you can probably run 7psi safely on the stock motor. just retard the timing
