Is this normal wear? (pics inside)
I'm in the middle of a cam/ heads swap and need to know if I have to replace the cam bearings as well. Thanks in advance!
http://theoildrop.server101.com/ubb/...?ubb=forum;f=3
I just bring it up because a lot of people think they are doing best by their motor when they are not.
LT1s are somewhat prone to front cam bearing wear due to carrying the extra load of the water pump, still what you have is non-typical and needs attention. Lubrication issue seems to be the logical answer as to why maybe do some readon on the link I provided and see if you learn anything.
The motor has had Mobil 1 5W-30 run in it and changed religously every three thousand miles. From the damage to the bearings, it would appear that the 5W-30 was not the best choice of lubricants. On another note, you can still see the cross-hatch pattern on the cylinder walls; I just find that odd.
M1 5w-30 and 10w-30 are too thin for this engine they actually boarder on being 20wt., but other brands are just fine in those weights, again I would refer you to the link I posted. Amsoil for instance tends to run towards the thick end of the weight range, so if running Amsoil a 30wt would be good but if going M1 then a 40wt is a better choice. Each are great oils you just have to do a little research to learn which one of their offerings is best.
Toole
224/236 dur 502/ 520 lift (1.5 r) 536/ 560 (w 1.6 r) 115 LSA +3 deg adv. gound in.
I'll be pulling the short block out tonight and tear it down to inspect the rod/ main bearings. With that said, it's now time to upgrade the pistons/ rods to a forged variety (probe), lower compression (around 9.5 to 1) and up the boost. Now I need to figure out how fast I can spin that S-trim Vortech and not max out those new 42 lb SVO injectors I just got. Any suggestions for impeller speed and the corresponding compression ratio?
