roller rocker
Old Jul 31, 2005 | 06:21 PM
ncarlson's Avatar
Default roller rocker
i have a set of factory lt4 roller rocker arms <1.6> . ? is will they fit under stock lt1 valve covers?
Old Jul 31, 2005 | 06:47 PM
97M6Formula's Avatar
yes sir.. If anything you just have to pinch the mounts a little where the center bolts go through
Old Jul 31, 2005 | 08:49 PM
96capricemgr's Avatar
Problem being true LT4 rockers are made for the production LT4s 10mm rocker stud NOT the 3/8th stud the GMPP heads and the LT1 heads use, so while the valvecovers are not a problem they still won't work on LT1 heads IF they are indeed production LT4 rockers.
