Fpr
With that and the ruined MAF in your sig it would be near impossible for Bryan to put a good mailorder tune in it.
The Maf works by trying to keep tiny resistors at a set temp and reporting to the pcm exactly how much electricity it takes to accomplish that and the pcm is programmed with tables to translate that into air flow grams per second. If you port it then the same amount of air travels slower not cooling the resistor as much and the MAF reports it as less air to the pcm then the pcm uses that FAULTY info to make fueling commands. A tuner can get the pcm translation tables back to correct but it is time consuming and should really be done with the aid of a wideband O2. That said most of the tuners are too nice a guys and don't make a point of telling people this stuff and just end up making you a "safe" tune which if anything has a little extra fuel to keep the engine safe. If people ask before doing things like this they will tell them don't but once it is done they wont say much and will just do like I said and send a safe tune. Most people aren't open minded enough to ask questions like you did and blindly defend their mistakes(I realize you bought yours like that), pride can be a bad thing when people need to stop listen and learn.
