383 Stroker Kit??
Old Aug 5, 2005 | 11:13 PM
LonnieJ71's Avatar
Default 383 Stroker Kit??
Who has the best deals on a stroker kit?? Is anyone using a Scat crank?? If so did you have any trouble having it balanced??
Old Aug 6, 2005 | 11:55 AM
pigpen's Avatar
You looking to go with a cast or forged crank?
I ran a scat 9000 crank for 6 years in my 383. Took some heavy metal to balance, but it worked fine, and held up to lot's of juice on a two stage kit, then 14psi of boost when the nitrous was pulled off. Crank looked great when I pulled it out earlier this year.
It's my understanding the the forged cranks are easier to balance. And the pricing is much better on the forged than it was 6-7 years back.
Old Aug 6, 2005 | 01:14 PM
METALBEAST's Avatar
Check ebay. They have some good kits for reasonable prices.
Old Aug 6, 2005 | 04:10 PM
travie319's Avatar
call jim at larry's performance....... great prices on scat......
I'm running a 4340 crank and h-beams from scat and it held up so far on my 383 with juice.......tell him Cris with the 383 lt1 sent you....
http://www.larrysperformance.com/data/location.html
Old Aug 9, 2005 | 08:05 AM
LonnieJ71's Avatar
Thanks guys for the info and I am planning to run with a forged crank, and I will get in touch with Jim, and look on ebay. Are the H-beams from scat as good as the ones from eagle?
Old Aug 10, 2005 | 06:17 PM
ScatStroker's Avatar
Scat and Eagle rods are generally used interchangably ... Both are 4340, are the same design and use the same ARP 8740 bolts.
$.02
Brian
