Pic of my new project (LT4 w/ "E" victor intake etc)
Old 09-12-2005, 09:55 PM
  #121
T/A KID's Avatar
The car is the Trans am the 96 with the LS1 Ws6 Front clip. Its a OEM style Ws6 hood (looks identical to the build of my buddy's 01 WS6. This is what I am thinking, for better fitment I am going to probably use solid motor mounts and drop the motor about half and inch or so, (may not be needed) The ls1 Front end seems to sit up Higher (more room under the hood) and I have a K-member which the front end moved up about an half and inch (I suppose becuase the lighter K-member let the cars front end come up from the ligher weight??). And of course there is a spot right in the motor of the hood that is near the cowl that comes down like 3 inchs or so, they can also be trimmed to be Flush with the rest of the inner hood.
As for the elbow I think for our setup we should mill it as much as possible at leats 3/4 probably more and Bret Bauer who is doing my intake Fabrication is going to mill some off the Top as well for added clearence.
Thats just my take on it. BTW I am sending my 195 AFR's to Lloyd this week should flow in the 290-300 range with the 2.05 intake valve.
Should dyno around 500RWHP with the ole 396 setup with a Mild cam. Brets' doing a 396 right now with a ported Super VIC a 300 CFM head in a A4 with 3:23's with a mild cam 23X/23X cam that he said will make 500+Rwhp.
Also something to note is that a Ported Super Vic flows so well you will see only about a 5-10 CFM loss on a 300CFM head. Sad thing for the LS1 boys that a 90/90 fast setup paired with a 300CFM 205 Afr head only see about 265 CFM air when bolt-on. I will see in the upper 280 lower 290 range.
LSWhat, lol
Old 09-12-2005, 10:00 PM
  #122
simple's Avatar
what size silicone coupler are you using too mate too the 90mm TB?
Old 09-12-2005, 11:04 PM
  #123
SStrokerAce's Avatar
Originally Posted by Tony Shepherd
Yes the Victor "E" is the Super Vic with the injector bungs. It will fit under an SS hood or a cowl inducted hood. Will not fit under stock hood. I will check my email tonight and give ya some more info.
Actually it's not a Super Vic for EFI, it's patterned after a intake they had for Super Stock type intakes. Sit down with both intakes in front of you and you can clearly see this. Basically it's really heavy and needs a good amount of porting to match a Super Vic.
BTW Joe Sherman only made 604hp on a Super Vic and 215RR with a 234/234 cam on a 365 cube motor.
A Elbow setup with some trimming and a Super Vic intake will fit under a stock hood.
I've done a ton of these things, and I think a Super Vic converted to EFI and changed over to a LT1 bolt pattern is a much better way to go than a Vic E.
All the plug ins for the intake make it fun.... vacuum lines, MAP sensors, PCV setups etc...
I like the throttle cable braket that Chris made for his... Also like the cruise control setup with this as well.
Bret
Old 09-12-2005, 11:07 PM
  #124
asudecat's Avatar
Well i got my flow #'s on my Dart heads. Allitle over 320 at .600 and about 328 at .700
Are you having you super vic ported? I was told that it flows well enough out the box. Just need it matched.
Did you do the front end conversion yourself?
Old 09-13-2005, 07:26 AM
  #125
Tony Shepherd's Avatar
Bret
I am going off what Edlebrock told me. They said it is roughly the same intake as the Super but with the injector provisions and also said you have to take quite a bit of material out to match the Super out of the box. So....with a little work........it is comparable to the Super and you do not even have to worry about drilling and welding injector bungs. I think the "E" is better bang for the buck. Either one is a great intake!!
Old 09-13-2005, 08:37 AM
  #126
T/A KID's Avatar
asudecat your going to have some Stout Heads on that motor of yours, should make nasty Power
As far as the intake Bret told me that the porting only really consists of working in the pleanum and then port matching the runners to the heads and blending everything in together. So it shouldn't have to have a Ton of work.
The Front End conversion was done by my oldest brother and his Friend (me helping a little, lol) He is a Professional body man and works at a Dealership doing this stuff all the time. I had the whole car painted at a Body shop with down draft paint booths. They put a Very Slick paint job on the car, Everything lined up accordining, but my brother is so picky about lining of the body that it took Several days to get everthing lined properly FOR THERE STANDARDS. I just got a Scanner at my house, when I get time I will take some pics, ( I think you guys will like my LS1 induction and my custom setup on my Delteq) Sucks to be a college student 5 days out of the week, lol
Old 09-30-2005, 09:18 PM
  #127
asudecat's Avatar
hey T/A KID
How's that car coming along?
You get your set-up back yet?
Old 10-01-2005, 07:13 PM
  #128
T/A KID's Avatar
Actually I delayed sending it out yet, Brett wants to do the intake blending when he has the heads, I have the money as of right now to get the whole setup complete but I have been real busy with school and other things. I will make a new thread showing off the setup when I get it done. I should Hopefully have it all completed within a Month. I am very close to getting everything sent off. I have everything setting in my shop ready to send.
Hows your setup coming alond man.
Old 10-01-2005, 08:25 PM
  #129
asudecat's Avatar
So many delays for me. WIth the hurricane down in Houston, it cause about a week delay or so. I should have it back surely in 2 weeks. I will get pics and whatnot. Right now were trying to get the paint and everything going.
I just finished with the front end conversion. The lines are way off. I'll have to work on that when I get some time. School is killing me.
Old 10-10-2005, 08:47 PM
  #130
asudecat's Avatar
Hey T/A Kid
I was meaning to ask you how much you were going to take off your elbow.
I think you might have said 3/4''??
Let me know cause im running the same hood as you.
Old 10-11-2005, 08:59 AM
  #131
T/A KID's Avatar
asudecat take a look at these pics http://www.gcfba.net/cgi-bin/ikon/ik...;t=5475;st=0;&
My elbow will probably be milled about the same as this one, Bret said he could mill the top of the elbow as well from some added clearence so we will do that as well. This is a pick from atljar intake setup mine will look alot like this one but will have some goodies on it. Thats probably more than 3/4 though, but thats no big deal. Well I finally have the ball moving again, I am sending the Intake setup to Bret Friday and I am sending my AFR's to Llyod Friday. Should have everything back with 3 weeks probably. Will post some pics then.
Old 10-11-2005, 09:03 AM
  #132
Ok...........after a few delays on my car........I finally have the ball rolling again. Should be dynoing it within 2-weeks.
Old 10-11-2005, 09:10 AM
  #133
T/A KID's Avatar
NICE I have a feeliing you going to make your Buddy with the 383 (TWS I think)JEALOUS, LoL
Old 10-11-2005, 10:02 AM
  #134
asudecat's Avatar
thanks
I should aslo have some pics going late next week or so. I will be sure and post. I guess i'll tell my builder to mill it 3/4'' and then go from there.
Yea I cant wait to see some #'s on your beast tony.
be sure and let us know.
Old 10-19-2005, 09:37 PM
  #135
Update:
This is the finished project. All that is left is to dyno tune which is scheduled for next weekend. Been working on it for some long hours!
What do ya think?
Attached Thumbnails Pic of my new project  (LT4 w/ "E" victor intake etc)-dcp_0849-medium-.jpg   Pic of my new project  (LT4 w/ "E" victor intake etc)-dcp_0850-medium-.jpg   Pic of my new project  (LT4 w/ "E" victor intake etc)-dcp_0852-medium-.jpg
Old 10-19-2005, 09:42 PM
  #136
monster7's Avatar
looks good tony
great job
Old 10-19-2005, 10:35 PM
  #137
Carbed4thGen's Avatar
Car looks sick Tony is it gonna be at SARS?
Old 10-19-2005, 11:15 PM
  #138
2MuchNos93LT1's Avatar
****** car looks sick keep up the good work.
Old 10-19-2005, 11:55 PM
  #139
Looks good Tony.
Bret
Old 10-20-2005, 07:05 AM
  #140
Thanks guys!!
Yes I will be at SAR on the 12th.
Quick Reply: Pic of my new project (LT4 w/ "E" victor intake etc)
