11 Second LT1
Old Aug 11, 2005 | 10:06 PM
strobelite's Avatar
Default 11 Second LT1
Finally got into the 11's last night with a:
11.98 @ 113 1.72 60 ft.
This is a heads/cam Lt1 on the bottle (75 shot)
Stock Suspension/Stock 3.23 gears.
It has a little more in it, Maybe 11.7-11.8. having a tunning issue with the 1-2 shift when under a 1.65 60 ft. Time. GOtta get the kinks worked out.
I'll keep ya posted
Old Aug 11, 2005 | 10:18 PM
Saad06's Avatar
awesome...
Old Aug 12, 2005 | 12:24 AM
FIREHAWK #07's Avatar
nice.... why not up the juice..... wet or dry????
Old Aug 12, 2005 | 11:22 AM
jeenyus's Avatar
what size cam and what type of heads?
Old Aug 12, 2005 | 11:25 AM
RealQuick's Avatar
seems awefully slow for a heads/cam and N20 LT1. Are you running at 5000ft or something? Who's heads/cam??
Old Aug 12, 2005 | 03:23 PM
95_Firehawk_Dude's Avatar
Yeah guy. Let us get some more details on the car.
Old Aug 12, 2005 | 03:33 PM
vin1382's Avatar
heads/cam alone should easily run that. whats your elevation? what are the conditions at the track?
Old Aug 12, 2005 | 03:44 PM
Shon Herron's Avatar
I would guess DA and weight is the limiting factors in this case.....
Old Aug 13, 2005 | 01:03 AM
strobelite's Avatar
LLoyd elliot heads/cam package. The LE2 package. With a 236/242 camshaft. 110. Yeah fairly slow for heads/cam and n2o. Havent got that part figured out yet. I am in Seattle, Wa not too sure what the elevation is here.
Old Aug 13, 2005 | 01:10 AM
BizZzatch350's Avatar
Moderator
wow, you should be deep low 11s with those mods
Old Aug 13, 2005 | 03:35 AM
regorih383's Avatar
nice numbers, do you have any idea of what kind of power its putting down?
Old Aug 13, 2005 | 02:33 PM
strobelite's Avatar
Low 12's is what i thought off the bottle but the car sint agreeing with me.
Dynoed right around 306 on a mustang dyno. 340 on the bottle.
Last night ran consistant 13.1's all night on motor. Even took second place in the car club challenge .
Old Aug 13, 2005 | 02:50 PM
jninan2k2's Avatar
Do you mean with just cam only? I mean there are plenty of people making that with cam only. Something is wrong with your set-up if thats all you're getting.
Old Aug 13, 2005 | 05:30 PM
Ari G's Avatar
maybe its doing 306 in each weel ,this is dam good time,with my mods i get 13.6
Old Aug 13, 2005 | 06:16 PM
METALBEAST's Avatar
Thats a mustang dyno also. So his numbers will be a bit lower.
Old Aug 13, 2005 | 07:59 PM
slow trans am's Avatar
theres definately something wrong with your setup.
Old Aug 13, 2005 | 09:55 PM
has there been a tune done?
Do you have an aftermarket TC? Which one?
Old Aug 13, 2005 | 10:02 PM
'68LT1camaro's Avatar
With Lloyd's heads and custom cam, you should be a little quicker. Keep us posted on your progress.
Raymond
Old Aug 14, 2005 | 07:27 PM
lt1fbody355's Avatar
I dynoed 359 all motor on a mustang dyno and all I have is heads and a smaller cam than you. It dynoed 466 on a 100 shot also.
Old Aug 15, 2005 | 01:51 AM
skinnies's Avatar
You definitely got a problem of some sort, you got a graph from the dyno? Are you running stock exhaust manifolds, a low compression motor, and lifting at the 1000ft mark or seriously what? My 9:1 compression motor with Lloyds heads and a small turbo cam, stock exhaust manifolds and stock y-piope, and no tune ran 13.1 at 103 with a setup that was built for boost.
