LS1 Heads on LT1
Old Aug 14, 2005 | 11:30 AM
T04Bird85's Avatar
Default LS1 Heads on LT1
I'm turbocharging a 383 stroker. It's an older LT1 block, and I was wondering if LS1 heads will bolt on without any modifications, and wil the benefits be worth the hassle of finding and buying them.
Thanks
Old Aug 14, 2005 | 11:40 AM
Turbo2.4Liter's Avatar
no they won't bolt on the bolt pattern is diff, coolant/oil passages are diff, valvetrain setup wouldn't work, etc
Old Aug 14, 2005 | 02:27 PM
brandboZ28's Avatar
Nope, wont even come close. Youre mixing apples with oranges.
Old Aug 14, 2005 | 03:47 PM
T04Bird85's Avatar
Thanks guys I'm new to this stuff but I'm learning.
Old Aug 14, 2005 | 08:13 PM
METALBEAST's Avatar
No, the LSX engines are a completely different platform. That's the bad news the good news is that there are some nice aftermarket heads out there that will work fantastic with your setup. Trickflow and AFR make some great LTX castings that feature among other things larger combustion chambers. The key with going FI is keeping your compression ratio low so detonation does not become a factor.
Old Aug 14, 2005 | 10:09 PM
BizZzatch350's Avatar
Moderator
You might as be putting 4.6 heads on your LT1. aint fixin to happen
Old Aug 16, 2005 | 04:02 PM
aggiez28's Avatar
looking at your post i thought you may be interested in this
link
also sellign the turbo setup for it
email me if interested
brook
