93 LT1 Chip Burning Question
Old Aug 16, 2005 | 01:21 AM
Speed Density's Avatar
hashtagBMW
Default Were TO Buy A chip burner
Were can i buy a chip burner and a dataloging cable?
I want to make my own chips
Old Aug 16, 2005 | 02:26 AM
hashtagBMW
Default 93 LT1 Chip Burning Question
I just dowloaded data master i program for PCM. So im new at this ecu stuff i was wondering what else i would need to burn chips? IM going to purchase pcmforless.com's chip burner package. BUt i need the burner itself and the daignostic cable. Someone plz put in some suggestions
Old Aug 16, 2005 | 08:11 PM
felton316's Avatar
Datamaster is just a diagnostic tool and data recorder, it doesn't do any burning. For that you would need a program like TunerCATS, that would allow you to edit the bin file.
Old Aug 16, 2005 | 09:04 PM
horist's Avatar
his car's a 93... they actually had swappable "chips" then (last of the F-Body's that was "chippable")
As for what you need... I'm not sure... but here's a TTT for ya (also modifying your topic and moving a copy to the LT1 section)
Old Aug 16, 2005 | 11:01 PM
felton316's Avatar
He still needs to edit a bin file then burn in on to a chip with the kit that he is going to buy from pcmforless.com. TunerCATS has been doing this for all the chipped ECMs for a long time.
Old Aug 16, 2005 | 11:45 PM
horist's Avatar
true... but he'll also need the hardware to "burn" the chip (and spare chips?) ... just wanted to make sure he was aware of this....
also .. can an LT1 Mod make a copy of this post to the PCM section? i fugged up when copying it and chose "move with redirect" ... I had meant this to stay in the PCM section also for additional assistance
edit: I've verified from a good source that you'll also need a "chip burner" .. aka something that you can plug your "chip" into and then rewrite it
Old Aug 17, 2005 | 12:51 AM
Firehawk17_201's Avatar
Ok so can you post all items need to put a programmed chip in.
Old Aug 17, 2005 | 01:03 AM
smoknta's Avatar
You should check out www.speeddensity.org
There are alot of informative people over there with 93's and that burn there own chips. You can also talk to Alvin from Pcmforless.
You just need a burner and the software that comes with it. You can get these from Alvin, or the same thing from Moates.com. Alvin just carries it in a complete package instead of individually pieces. If you want to be able to edit the file yourself and do your own tuning you will need a program like Tunercat.
Old Aug 17, 2005 | 03:30 AM
hashtagBMW
Thanks for the help guys.
Old Aug 17, 2005 | 07:23 AM
Tony Shepherd's Avatar
For years I used a PocketProgrammer II to burn chips. I used tunercats to program the bin files and datamaster to log data. You will also need a UV eraser unless you use the re-usable overwrite chips.
Old Aug 17, 2005 | 10:24 PM
rkinney's Avatar
Check out Moates.net. You can get eveything you need from this site. the burner is like $80, then just get some chips and the adapter board. You can also download tunerpro from a link on this site. It's the editing software to change the bin file. It's also free, but you can donate to the cause. You will need the DA3 .ecu file to look at the bin file. There is also a datalogging program that works with tpi and 93 lt1's on this site. I've used it with the cable I made with no problems. Hope this helps.
Old Aug 18, 2005 | 04:52 AM
Lafngas93z28's Avatar
I have a chip that would workgood in your car. Its a custom burn from Ed Wright. If you want it, I paid $375, I'll take $150 shipped. Let me know.
Alan Mc
