Do I have the right setup or not on a 398???
Old Aug 17, 2005 | 05:17 PM
1 F8L Z's Avatar
Default Do I have the right setup or not on a 398???
What do you guys think on my setup and what time and hps should I be seeing??? Here my setup
398 Ci .40 overbore LT4 Block
Decked/Honed
AFR 220 Heads with 290 intake 207 exc flow
Lunati Nitrous Pistons, 4340 Crank, 6" Rods, Chromolly Rings
Crank was dynamically Balanced on the block with the flywheel and ATI Balancer.
ATI Balancer
AFR Hydra Rev Kit
LT4 Intake match ported
58mm TB
Crane Gold 1.6 adj. RR
upgraded lifters
242/248 @ 112 LSA Cam 575/600 lift
Chromolly Pushrods
Upgraded springs to match cam
Canton 8qt Oil pan
High Volume Oil Pump/pickup
Hooker LT header
cutout
10 bolt 323
built automatic
Old Aug 17, 2005 | 11:01 PM
regorih383's Avatar
What exactly are you planning on duing? Is it going to be a track only car or daily driver.
Old Aug 18, 2005 | 02:33 AM
NXSLT1's Avatar
You have a clutch listed then at the bottom a built automatic, is this built automatic something other than a trans?? Don't know what it'll run but if it's an M6 and yer gonna run at the track alot then I'd suggest investing in a 9" rear.
Old Aug 18, 2005 | 06:10 AM
METALBEAST's Avatar
Ditch the 10 bolt and 3.73s. Go with a 12 bolt or 9" and some 4.10s.
Old Aug 18, 2005 | 09:06 AM
outdooricon's Avatar
wow, 398 huh... how'd you do that? I thought there was only a 396, how'd you gain those extra 2 cubes?
Old Aug 18, 2005 | 09:19 AM
Black97's Avatar
.40 overbore
Old Aug 19, 2005 | 04:53 AM
1 F8L Z's Avatar
it gonna be a daily driver and will look into a 12bolt or 9 's when I get $$$. For the moment the 10 bolt will have to do.
Old Aug 19, 2005 | 06:50 AM
Black97's Avatar
242/248 duration is pushing the limits of daily driving
Old Aug 19, 2005 | 07:38 AM
MEAN LT1's Avatar
So what is it, a autotragic or M6?
Old Aug 19, 2005 | 12:37 PM
1 F8L Z's Avatar
Wink
it an auto bro, will change it to m6 when tranny goes out. Is the cam right for my setup because it a grind cam. It will be mostly weekend but need it for a daily driver in case my hooptie dies.
