I figured someone else would have this problem with ALDLCable.com's cable. I bought one a few weeks back for logging/programming. Per their website says you can. This is not the case. I've emailed them about it, and I've even pushed them as far as sending Ion at Madz28.com a cable to test. Ion says he got the 95+ obd2 cable to work. However I did not. Ion hasnt replied on if the 94 cable works or not.
I did my own testing. With every baud setting, my laptop, my pcm, my car, Tunercats would not connect. So I thought it was the car, so I pulled the pcm, put it in my buddies 97 t/a same error.
Finally I bought a usb cable from Moates.net and it works perfect!
