Aldl Cable Wont Read
Old Aug 19, 2005 | 05:59 PM
Speed Density's Avatar
hashtagBMW
Default Aldl Cable Wont Read
i just got this cable for dataloging and i cant get the bitch to connect to the laptop. I do hypertest and if i touch the male end of the plug data streamlines on the program. If i do an aldl test at 8912 buats it fails. The god damn ALDLcable.com isnt helping me at all they just ingore me. I need this thing to work i dont know whay its not. The car is on, not runing but on , the laptop is on the programs are on. My serial port is connected and runnin 9600 bauts. I NEED HELP GUYS PLEASE!!!!!!!!!!!!!!!!!
Old Aug 19, 2005 | 06:09 PM
rkinney's Avatar
What datalogging software are you using?
Old Aug 19, 2005 | 06:19 PM
hashtagBMW
i have TTS datamaster and i cant get the calbe to read
Old Aug 19, 2005 | 06:52 PM
rkinney's Avatar
Did you go through the whole bit of selecting record aldl from the file menu. Then the screen pops up that has record, monitor, stop keys. Go to file and open up a uni file or create a new one, then open it. You can hit record or monitor to just watch and no record. Not sure if you did this, but just trying to help. I built the two transistor interface cable from a schematic on the net for about $20, all parts from radio shack. It works fine most of the times, but I do get the data error every now and then.
Old Aug 19, 2005 | 07:18 PM
hashtagBMW
i paid 50 from aldlcable.com, and there not hlepin me at all. I did all that you said but the TTS says PCM not Sync. and then it wont work
Old Aug 19, 2005 | 07:25 PM
rkinney's Avatar
One more thing. Did you select your com port. If not try that and select the port you are using probably com 1. I have had this happen to me a few times, but it would start working again.
Old Aug 19, 2005 | 07:31 PM
hashtagBMW
RKINNNEY YOU HAVE AIM BY CHANCE you seem stuffed in this area for knowledge!!!!!!
i dont know were to select it at
IX CaMaRoZ28 XI
Old Aug 19, 2005 | 07:41 PM
rkinney's Avatar
pm sent
Old Aug 19, 2005 | 07:49 PM
rkinney's Avatar
Go to setup in the data aquisition window after you open record aldl from the file menu.
Old Aug 19, 2005 | 08:07 PM
hashtagBMW
k i did
then i go to com port and it show com 4
Old Aug 19, 2005 | 08:10 PM
rkinney's Avatar
Try com 1.
I just got mine to work, but then quit again. Then one of my connections to the transistor in my cable broke. I have to fix this now. I would check terminal tension at your aldl, then if that's not the problem, you might have something wrong with your cable. If you can open up the serial connector case to see if anything is burned or a broken connection. Just a thought.
Old Aug 19, 2005 | 08:12 PM
hashtagBMW
i dont have the choice for com 1 its only 4, ima open my cable
Old Aug 19, 2005 | 08:21 PM
rkinney's Avatar
Don't know then. I have a selection for com 1 and 4, but I use 1. Are you using the free trial version of datamaster with the 20 free recordings, then that you have to buy the license? Just curious?
Old Aug 19, 2005 | 08:23 PM
hashtagBMW
the free one
and i still have 20 left
Old Aug 19, 2005 | 08:30 PM
rkinney's Avatar
Just sent you another.
Old Aug 19, 2005 | 10:02 PM
hashtagBMW
I Got It~!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
Old Aug 19, 2005 | 10:54 PM
NXSLT1's Avatar
When you say you did the hypertest do you mean hyperterminal in windows? And did it pass or fail this? What version of windows are you using??
Old Aug 20, 2005 | 12:42 AM
hashtagBMW
Windows ME and yes hyperterminal. I got it to work with TTS datamaster but now it wont connect to Tuner RT
So im confused.
Old Aug 20, 2005 | 01:47 AM
NXSLT1's Avatar
Are you using a PCMCIA card for a serial port or a usb adapter or does the laptop have a built in serial port on the back? The usb adapters hardly ever work right. I use a PCMCIA card and I was using Windows XP. My problem was that XP wouldn't let my card communicate right even though it showed it as being installed so I had to download a hotfix. This hotfix is also in windows update. I can't remember if this problem was just under XP or if it applied to ME too. I'll see what I can dig up.So you finally got it to let you use datamaster on the car?? What did you have to do to make that work?
Old Aug 20, 2005 | 01:58 AM
hashtagBMW
Default ALDLCABLE.com
These guys have crappy *** customer serivce. I needed help and the just said read the paper taht came with the cable. THEY SUCK *****
ALDLCABLE.com ALDLCABLE.com
