OBD1 w/ OBD2 connector...
Old Aug 21, 2005 | 12:57 PM
shaolinworldwide's Avatar
Default OBD1 w/ OBD2 connector...
I have '95 with and ODB1 and it has OBD2 conneting pin.
Is there a code reader made for this car? Went to Auto-Zone and they said OBD2 will work, I don't believe that.
According to the manuel, I need a ODB1 scanner with a special connector. Where can I find one? Will the OBD2 work?
Thanks.
Old Aug 21, 2005 | 01:02 PM
HBHRacing's Avatar
OBDII will not work since it is not an OBDII control system. Any "good" scanner will work around this, but there is no cheep option that I have found.
TwoFast4Lv's Avatar
Many 94 Vette's had the same plug You use a OBD-I scan tool with a OBD-II cable
