z06 maf sensor vs stock..
Since you are trying to run it untned you must not understand how these work they use an electrical frquency to heat the little wires to a specific tempature/resistance that frquency is then sent to the pcm and the pcm has to be PROGRAMMED with the appropriate tables for that MAF otherwise the info will do nothing but cause problems.
Since you appear not to want to hear this is not the right way to go with mods from us why not ask you tuner what he thinks, don't ell him you are using it first though as some of them are too nice and too customer friendly to tell people to undo mistakes they have already made.
I have several people running those on LT1 cars. I used one on my stock engine for two years before I built my 383" Not much gain on a stock engine, or even a head & cam engine. 4 or 5 hp if your lucky. Usually less. It will run rich if you just plug it in with no tuning. No problem making it run as well (the same) as a stock MAF sensor, on even a stock engine. I would expect any decent tuner to have tables developed for that sensor by now. Pretty comon deal.
Good luck, Ed
I have been using them for about four years now. Most guys that want them don't need them. Ditto bigger throttle bodies, and too often injectors. It's the "bigger must be better" syndrome.
Ed
