Injector size?
Old Aug 30, 2005 | 04:33 PM
cmerc's Avatar
Default Injector size?
This is a list of the mods done to my engine by the original owner, Note that the injectors are 27LB; I am running approx 65 psi fuel pressure and am wondering if these injectors are big enough. If not what size should I consider, I am suspicious that at least 2 of them are failing and am considering larger ones if the experts think these are too small, also if I went to larger injectors would I need to reprogram the PCM for the new injectors?
383 stroker 550hp dynoed /AFR-210 Heads Ported w/210-160 valves/Comp Cam 1.550 Springs Titamium Retainers 10 degree locks/LT4 intake Port Matched to heads/Adjustable Fuel Regulator/Callies 4340 Knife Edged
TPIS Solid Roller With Comp Cam Rollers/Cloyes Roller Chain/Titan Oil Pump - Adj. Oil pressure next to dry sump
Billet Fabricated Aluminum Oil Pan 7qts.
Tall Billet fabricated aluminum valve covers w/spring oilers
30 over JE Pistons 10.3 with 6" forged alum. Eagle Rods
ARP head studs Bottom end bolts and Deck plugs
Balanced & Clearnced Bore & Hone with deck plates Align honed/EGR block off - no air pump/Lingenfelter 58mm throttle body/Granatelli Mass air flow sensors - G2 high flow rubber bellows/27lb. Injectors/In Tank Fuel Pump - Handles 500hp/TCI Damper
Meziere elec. Water pump 160 degree thermostat
Be Cool Alum Radiator/Performance Dist. 9mm Live wires
MSD 6AL - MSD Coil - More Performance opti-spark
S/P Steel Billet Flywheel/Centerforce Clutch
Hooker Longtube Headers W/Ypipe & jet coat
Old Aug 30, 2005 | 04:57 PM
Black97's Avatar
If 550 is flywheel hp you should get 42lb .. Click to the link and see what you have to do.. The numbers are flywheel hp not rear wheel hp..
http://paradox.shacknet.nu/dave88lx/.../injectors.htm
