headers
Old Sep 3, 2005 | 11:54 AM
mike2244's Avatar
Default headers
i was looking at buying headers. i looked at the bbk shorties. are they any good.
Old Sep 3, 2005 | 11:59 AM
blind527's Avatar
Get long tubes if you're not worried about emissions. Take out the EGR and AIR systems as well.
Old Sep 3, 2005 | 11:05 PM
Jameslt1TA's Avatar
If your gona go with longtubes i which i would highly recommend, go with pacesetter coated ones for there low price...like 400 bucks. They will make just as much power as hooker but cost less and last just as long. If you want them to look good forever go with kooks stainless steel but i think they are around 700-800 bucks or so.
Old Sep 4, 2005 | 04:07 PM
Camaro 0wner's Avatar
Click Here Are these a good buy. Whoever started this post, you can take a look at these to. I think they are ok, but I want to be sure. I don't think it comes with a Y-pipe though.
Old Sep 5, 2005 | 10:42 PM
Anyone have an idea?
Old Sep 5, 2005 | 11:30 PM
NW Iowa WS6's Avatar
BBK or any other shorties 5-10 rear wheel tops. ANY longtbues with 3" Off road Y 15-25 depending on other mods. Get the pacesetter and call it a day.
Only thing I see shorties really worth the time and money for is turbo set-ups.
Old Sep 6, 2005 | 12:07 AM
CLICK HERE Are those a good deal?
Old Sep 6, 2005 | 12:15 AM
blind527's Avatar
Aren't those the same ones you put in the other threads? Those ones seem a little too cheap. Like you said in the PM's, you want a system done right w/o problems the first time. Get a good set the first time so you won't have any problems. Pacesetter is good, but I'm not sure about those in particular.
Old Sep 6, 2005 | 12:53 PM
94strokedz's Avatar
Steer clear of BBK!!! Thats my opinion. I bought a BBK 58mm throttle body about 4 months ago and its the biggest piece of shi* I ever bolted to my car. It is a cheap casting with the butterflies milled off center by about an eighth of an inch. The intake still has much of the rough cast surface on it, I had to deburr all mating surfaces as they were not deburred, at all. And last but not least, the shaft that the butterflies turn on came loose and I had to reweld the joint where the throttle cable meets. The car decided to idle at about 3500 rpm's, at a traffic light, in the middle of cop ville. Has anyone else had problems with BBK?
Old Sep 6, 2005 | 01:29 PM
Wow, thanks for the heads up.
Old Sep 6, 2005 | 02:11 PM
97LT1's Avatar
5-10 hp get real.
Old Sep 6, 2005 | 02:23 PM
blind527's Avatar
Are you saying 15-25 RWHP with LT headers isn't realistic? It sure is....Especially if you have other mods.
Old Sep 6, 2005 | 05:50 PM
97LT1's Avatar
Are you talking to me?
If so i was saying it should be a tad more like at least 15-20 for shorties. I said 5-10 hp is bullshit if your adding headers. I honestly dont really see how there will be a huge difference between the two unless they are stepped.
Old Sep 6, 2005 | 05:52 PM
blind527's Avatar
Ah, I was just confused, sorry man. No worries
Old Sep 7, 2005 | 12:21 AM
DD97TA's Avatar
save money and get a nice set of longtubes... **** i went with pacesetter and they do the job just fine... i got a set for under $400 with the offroad ypipe from byunspeed...
Old Sep 7, 2005 | 10:40 AM
I really want to find this guy. I will buy them now if he has them.
Old Sep 7, 2005 | 12:48 PM
blind527's Avatar
Sounds look a good deal, just make sure you have a catback system that will fit
