Should I get these?
Old Sep 6, 2005 | 07:39 PM
Camaro 0wner's Avatar
Default Should I get these?
Headers I'm giving serious thought to buying these headers with the Y-pipe tomorrow. If you guys could be honest and tell me what you think about these headers, I would really appreciate it. Do you think I will have problems, will it bolt right on to my current exhaust? (I have flowmasters with no cat) Are they crappy and might give me problems down the road? Does it come with everything I will need for installation? Will I need different bolts or something? Gaskets? Maybe better ones? Anybody have them or know someone who does? Thank you for the help in advance.
-Jay
Old Sep 6, 2005 | 08:16 PM
Speed Density's Avatar
hashtagBMW
buying off ebay has its ups and downs, why dont you just save up the extra dough and get some pacessetters longtubes.
Old Sep 6, 2005 | 08:25 PM
SmokedOutZ28's Avatar
-Jay
i got my first set of headers from them!! everything worked out great with the seller and communication was top notch.
Old Sep 6, 2005 | 08:27 PM
your correct, but to add i bought my 2nd set of coated headers from a company on ebay, they even priced matched a GP on this site. the guy was totally cool i waited 2 weeks for the coating but buying stuff from ebay have been a pretty good experience for me. you just need to pick them right.
Old Sep 6, 2005 | 08:30 PM
blind527's Avatar
Has anyone used a spray coating? Those don't seem too bad. If you have a good feeling about them go ahead and pick them up.
Old Sep 6, 2005 | 09:47 PM
I thought those were pacesetters? Also, what do you mean buying from ebay has its ups and downs? Where would I get a set of pacesetters that your talking about? Some local store, or online somewhere? These seem like a good deal, but they will end up rusting, right? With the Y-pipe, it will come out to about 410 without shipping. I figure that's not too bad. Do you guys agree?
Also, someone else said they delt with these people before. Did the headers last you for a long time? Why did you end up getting something different? What did you end up getting and was that a good deal also? Thanks
-Jay
Old Sep 6, 2005 | 09:51 PM
blind527's Avatar
-Jay
This place has Pacesetter
Just for your info...All headers will eventually rust, no matter WHAT coating you put on them. Ceramic coating found on Jet Hot LT's etc. is made for transfering heat out of the primaries and keeping your engine and its surroundings much more cool.
Old Sep 6, 2005 | 10:14 PM
im using a coating spray on my first set for the 95 they seem to be fine, no rusting and the headers look like new besides the dirt. i got the coating from summit and about 5 cans and 3 coatings with heat treatment there fine.
Old Sep 6, 2005 | 10:37 PM
That place has the same pacesetter headers that are on ebay. (The ones I showed you) They are the same price, but the difference is ebay has the matching Y-pipe. They had some Y-pipes on that site for like 250 or something. The matching Y-pipe for 125 seems pretty reasonable now. Will it be a "huge" difference if I don't get coated? Because I could always wait a little longer and get the coated ones...I just personally thought it didn't mater. Also, I have flowmasters without the cat. When I first got my car, the people told me it came with flowmasters. So my questions is, what size do you think my exhaust is? I haven't gotten under to measure, but would the basic flowmaster exhaust set up be 2.5'? That's what i thought. Now, does that mean I have to get 2.5' headers? I would think so, otherwise I would have to get bigger pipes, correct?
Old Sep 6, 2005 | 10:42 PM
blind527's Avatar
Coating only helps with heat transfer. Like stated above, just get some spray that coats the headers and put a few cans on. Is your existing system welded or clamped? If it's welded, you're going to need to cut it, then get some sort of coupler to connect a 2.5" pipe to a 2.5" pipe. Those headers seem fine, I would pick some up with some spray, coat them and let them dry . They will look better too. If the car still has the stock tips, then it's probably the stock cat back system. Someone may have put Flowmaster mufflers in.
Old Sep 6, 2005 | 11:19 PM
What is the stock cat-back system? If it is the stock cat-back system, what should I get it changed to, if anything? (What type of change would be best for those headers)
Old Sep 6, 2005 | 11:27 PM
blind527's Avatar
It's all preference. Check out ls1sounds.com to see what kind of systems people have
Old Sep 7, 2005 | 12:12 AM
Alright, so performance wise it doesn't matter?
Old Sep 7, 2005 | 12:16 AM
DD97TA's Avatar
i would send a pm to byunspeed... he hooked me up with the headers and ypipe for under $400 out the door...
Old Sep 7, 2005 | 10:39 AM
Damn, how do I PM him? I don't know how to find people...
Old Sep 7, 2005 | 11:09 AM
click on user cp at the top, then on the left hand side of the screen under private messages, click on send new message enter his user info and the message.
Old Sep 7, 2005 | 02:05 PM
Alright, I tried to send a message to him, but it said cannot find member. Is he not on Ls1 tech anymore, or did you not spell his name right?
Old Sep 7, 2005 | 02:35 PM
old and good's Avatar
Do any of you guys know if there is a online LT1 store in virginia? preferably near norfolk or virginia beach
Old Sep 7, 2005 | 02:38 PM
blind527's Avatar
No but there is a good place in Maryland called Marylandspeed.com. I got my headers and y pipe from them. Branden is an awesome guy, great customer service.
Old Sep 8, 2005 | 03:16 PM
StealthFormula's Avatar
did u get the Thermo-Tec stuff? or VHT header paint? thanks
