Questions on stroker setups
Old Aug 23, 2005 | 06:01 PM
Speed Density's Avatar
hashtagBMW
Post Questions on stroker setups
Just a question on how much some of you guys paid for all the parts to make the kit, or were you got a full kit, how much, how much was labor?
Old Aug 23, 2005 | 06:08 PM
asudecat's Avatar
396 Eagle Kit - $1497 H-beams hell-fire rings, 4340 crank
L19 upgraded bolts- $100
All block work - splayed 4 bolt main caps, decked, honed, bored, balanced assembled. this is also basically putting together the motor, w/timing chain oil pan, rockers, lifters,everything - alittle over $1000
Old Aug 23, 2005 | 06:10 PM
hashtagBMW
EVERYTHING EXCEPT EAGLE, HOW MUCH i hate eagle ive heard nasty stuff aboout em!
And for a daily driver is a 396 a little much?
Old Aug 23, 2005 | 07:56 PM
CountryMuzicZ28's Avatar
www.golenengineservice.com and theres nothing wrong with eagle
Old Aug 23, 2005 | 09:54 PM
hashtagBMW
I dislike eagle, but if anyone else has any input plz feel free to add it.
Old Aug 23, 2005 | 10:09 PM
asudecat's Avatar
yes sir.....daily driver. atleast 200 miles a week.
It doesnt matter if it's a 396 or 383. That doesnt classify it as NOT A DAILY DRIVER.
The cam more likely decides whether it's gonna be streetable.
Old Aug 24, 2005 | 02:49 AM
97M6Formula's Avatar
I have eagle 4340 crank and rods and diamond pistons 4 bolt callie splayed mains 2300 fro blue printed balanced short block
Old Aug 24, 2005 | 05:14 AM
Black97's Avatar
What is your camshaft specs? If its secret you can write 23x/24x like that.. and lobe separation? (lsa)
Old Aug 24, 2005 | 08:41 AM
asudecat's Avatar
Dont have the cam yet. Will in a couple of weeks. Motor is in process of being built. But It will be streetable as far as Im concerned.
Old Aug 24, 2005 | 02:29 PM
hashtagBMW
What are some # on a 383 vs a 396?
Old Aug 24, 2005 | 05:18 PM
urbanhunter44's Avatar
on the dyno you won't see too much, the biggest difference will be in the torque. Also remember that with a larger CID motor, the same cam will be more streetable than on a smaller (355ish) motor.
Old Aug 27, 2005 | 01:43 PM
asudecat's Avatar
Really???? I've never heard that. Can anyone else confirm this???
Old Aug 27, 2005 | 01:52 PM
monster7's Avatar
yes the volume will absorb more cam
its very true
Old Aug 27, 2005 | 01:53 PM
monster7's Avatar
oh and a 383 stroker cost about
elenteen thousand dollars
Old Aug 27, 2005 | 02:10 PM
travie319's Avatar
I have a 383 with a 23x-24x less than .600 lift and a 110 lsa it's my daily driver and I drive all over the place sometimes over 200miles a week......
scat 4340 crank and scat 4340 h-beams....je pistons .......all great products and reasonable pricing....call my buddy JIM at LARRY'S PERFOMANCE and he'll give you some great deals if you find it cheaper somewhere else I'm sure he'll work with you....
tell him CRIS with the lt1 sent you........http://www.larrysperformance.com/data/location.html
Old Aug 27, 2005 | 02:13 PM
Its true GO BIG or GO HOME
Old Aug 27, 2005 | 02:46 PM
Vendetta's Avatar
Originally Posted by monster7
oh and a 383 stroker cost about elenteen thousand dollars
elenteen?
Old Sep 3, 2005 | 03:40 PM
hashtagBMW
Default 396 ci??
Im really liking the stuff ive been hearing about the 396 compared to a 383 stroker. Anyone else got any good input on either of them? IS one better then the other? Cost more? Performe better?
Old Sep 3, 2005 | 04:03 PM
BigKap94z's Avatar
396 is more expensive and marginally better. I would build a 383 again before a 396. I believe in doing it right the 1st time, so if i was going to waste the money on a 396 I would make sure I had a good set of AFR 210-220's with a Super Vic intake converted, and a big custom cam. Machine work was more when i priced it for the 396, and many shops didnt want to do it. I feel that with the same money a 383 will perform just as well.
Old Sep 3, 2005 | 04:24 PM
LT1PWRD's Avatar
I agree w/ what he said, if money isn't a prob. and you have a GOOD machine shop avail. The 396 makes a forged crank mandatory(no one makes a 3.875 stroke in cast) which means more $. Besides The Eagle cast steel crank and rods are good to 550 FWHP or better (NA) when properly balanced and assembled. i've seen balanced Eagle 383 kits for $1195.00 shipped that include SRP pistons,bearings,rings,Eagle crank+rods. Also like he said some machine shops are "afraid" to clearance that much cuz they dont wanna poke the water jacket. plus u won't feel in the seat of ur pants those extra 13 C.I.
