More Oil cooler questions
Old Sep 7, 2005 | 06:24 PM
cmerc's Avatar
Default More Oil cooler questions
I am going to replace the stock oil cooler setup on my '94Z, should I just block the radiator and water pump nipples, or run a line between the radiator and water pump
Old Sep 7, 2005 | 08:40 PM
01WS6/tamu's Avatar
If you could clarify a little more we could help not quite sure what ur talking about. Engine, trans, or power steering cooler.
Old Sep 7, 2005 | 10:43 PM
FIREHAWK #07's Avatar
think he's talking about the engine oil-oil cooler....
Old Sep 8, 2005 | 06:14 AM
cmerc's Avatar
Sorry guys, it's the engine oil cooler.
Old Sep 8, 2005 | 11:39 AM
01WS6/tamu's Avatar
Just junk tht pos and get a filter adaptor for an 85 chevy pu and bolt it on. Then just connect the water lines end to end with an adaptor like you would use for a heater core bypass. You could also go straight to the source of whre each hose comes from and run a new line with no splices.
