help pick my heads!!!
Originally Posted by 30AnvZ28
It is my only car and therefor must be reliable.
Originally Posted by SS MPSTR
450rwhp N/A through an A4 and reliable? Good luck. I suggest you invest in a DD. At that power level, many of the parts are on borrowed time.
thank you.
i'm sure you can achieve that goal but... reliably and daily driven...more then likely isnt going too happen
So if and when I make this... I will be the first to let you all know. Im one for making goals, and showing people that things are possible if you work hard enough, and im confident this will happen, but for all of you who feel it wont, thats fine... theres more than enough of you who have told me i cant do it, and theres a small few, who think i can, and those that think i can, are helping me every way possible to show you it can be done. thank you for your imput for those who gave it, and thanks for the encouragement for those who said i cant do it.
I suggest you stick to the topic... like I said, this isnt a must, just a hope. If things are built right, anything is possible.
I know its going to be hard... espically with whats happened the last couple weeks, and this first build probably wont make it, but I need the car running, and the heads wont be done for months due to back order... so as of now, the car will just have a basic set of heads on it, and Ill have the AFR's built, and have them on hopefully the first of the year.
