Wanting to put a solid cam in my lt-1...
The hyd roller cams have come a long way and they are making good power at higher rpms, mind you that with a 383 you may not need to wind her that high, considering the high piston speeds.
That being said, the solid cam is louder, valvetrain parts like springs and retainers are slightly more expensive since you need higher quality parts there, and you replace them more often. The up side is that you make more torque and power with an equal grind compared to a hydraulic because the lobes are more aggressive in most cases and driveability is usually slightly better with the solid.
These are generalities, but I currently run a solid in my car. The old grind was a 248/254 duration at .050, the new grind that just got installed is a 252/262 at .050 and I still run the stock PCM. This cam should peak at 6800-6900 in my 383 and make good torque throughout the powerband. We'll see in the next week or so when it goes on the dyno.
I would not recommend the solid roller for a daily driver even though some guys use it as such and it can be done. If you have maxed out all the other components on the car and want to squeeze a few more HP out of the setup, then it may be a good idea and worth the cost.
