LT1 problems
1994 camaro z28 103000 miles auto.
When you say no power does it bog till a certain RPM then shoot off? Check for possibly a burned plug wire. When is the last time you changed plugs?
its not too terribly bad it just takes some time you have to take your intake boot out, drain your coolant, remove the water pump, remove the harmonic balancer, before you can take the water pump off you have to remove the AIR pump bracket and once you get in there there are just three bolts holding the opti in there and it just slides right off getting the new one on there takes some fiddling til you get the splines lined up correctly but its not hard it just takes some patience
good luck
just a thought could i be right? would the knock sensor trip the SES light?
DOES ANYONE HAVE ANY IDEAS???? PLEASE RESPOND THANXXXXX
