K&N Filter Kit advice?
Old Sep 13, 2005 | 09:05 AM
jkichline's Avatar
Default K&N Filter Kit advice?
Hey guys,
I'm looking to put in a K&N filter kit from Ebay for ~50-60 bucks. Is there anything else that should be considered like fuel flow, timing, ICM, etc.? What do you guys recommend?
Old Sep 13, 2005 | 09:36 AM
Siphon's Avatar
Originally Posted by jkichline
Hey guys,
If your gettin the FIPK kit. . .you need to be wary of sucking up water. I found out the hard way. . .and lost an engine.
Just install it and your good to go. No mods really needed.
Old Sep 13, 2005 | 10:47 AM
jkichline's Avatar
How did you end up sucking in water? I definitely need to avoid that!
This is the one I'm looking at... It's not FIPK.
Ebay Ad
Old Sep 13, 2005 | 12:46 PM
Camaro 0wner's Avatar
That one doesn't look bad and you won't have to worry about sucking up any water with that one. Although, I don't think you will see as much of a hp gain with that. If I was you, I would save my money and get a K&N or Moroso CAI. It will suck up more air. But, you can do whatever. This is pretty cheap, so it depends how you look at it.
Old Sep 13, 2005 | 12:48 PM
Speed Density's Avatar
hashtagBMW
o ****, i suckd water too. it was raining bad i didnt see a puddle and i hit the puddle and my car died right there!!!!!!! i recomend taking ur FIPK off in rainy seasons!! .02
Old Sep 13, 2005 | 01:07 PM
asudecat's Avatar
I've got a K&N FIPK that was used less than a month, and I dont drive very much. I sell it to you for $100 + shipping. Perfect condition.
I also have the 1LE elbow as well for $50 That was used for about 2 weeks.
Old Sep 13, 2005 | 04:48 PM
94greencamaro's Avatar
Dont take off the CAI in rainy seasons. Thats a waste of time and performance. Just dont drive like a dumbass when it rains. Dont hit big puddles that are going to spray water all over your ****** filter and you will be fine. I drove around in the rainy season with mine and i even have a big hole cut in the plastic piece that guards the filter. Maybe you can take it off if you are in New Orleans.
Old Sep 20, 2005 | 11:11 AM
jkichline's Avatar
What do you guys do to avoid intaking water? On my intake elbow, there is a port underneath that attaches to a closed tube. The port is not open so I took the tube off. I didn't see any reason for it to be there. But now I'm thinking that it could be used as a water trap or something....
What about you guys with Ram Air??? How do you avoid intaking water?
Which kit gives the most HP gain? Anybody got any #'s on that?
Old Sep 20, 2005 | 01:15 PM
quick93transam's Avatar
the ram air hood have drip holes on the bottom side and there is a baffle in front of the filter. the water hits the baffle and drips the to bottom and leaks out of the holes. a lot of guys take that baffle out though. unless it raining unbelievably hard the likelihood of rain making it into the engine is slim. if the water gets deep enough to get up to that filter you have more problems that worrying about your car.
