383 Injectors?
Old Sep 17, 2005 | 08:05 PM
BlackZ36's Avatar
Default 383 Injectors?
I just put in a 383 stroker and i need ne injectors...should I go with the Accel 30 lb or the SVO 30lb...is there any difference?
Old Sep 17, 2005 | 08:31 PM
96capricemgr's Avatar
You don't want Accel, best case with those seems to be hard starting, worst involves maybe needing a new car. Might consider something a little bigger too depending on how aggressive you plan to get.
Old Sep 18, 2005 | 02:40 AM
BlackZ36's Avatar
Well its a 383 alll forged, right now it has a cc305 but i plan on a gm847 with worked lt4 heads soon and im gonna eventually do a tnt 200 hp wet kit...i just ordered the 30lb accels from jegs...but i might cancel the order if they are bad...i need some feedback on them soon
Old Sep 18, 2005 | 03:13 AM
regorih383's Avatar
to start off ill let you know that 30s are to small, I have a 383 and went with 36lb
Old Sep 18, 2005 | 08:02 AM
Go to camaroz28.com and search Accel, don't just take my word for it.
I had a small set on a stock car and while it ran better than it had with the one dead stocker and 7 widely flow varying ones it started much harder even with tuning and we could never get the fuel trims down well and milage suffered because of it.
I would go with the SVOs or Racetronix.
Old Sep 18, 2005 | 10:15 AM
SS MPSTR's Avatar
36lb Bosch EV-14's here. Awesome injector.
Old Sep 18, 2005 | 04:19 PM
travie319's Avatar
I have 30lbs from accel and they run great on my 383....I also have a bigger cam than the gm847.......
Old Sep 18, 2005 | 04:47 PM
flyinZ's Avatar
Id go with a set of 36's or 42#'s..I've got a set of SVO 42's, but a little bigger cam then that...Plenty of room to breathe.
Old Oct 3, 2005 | 12:56 AM
Zepp's Avatar
I have used both on my 383 Stroker. I originally had the Accel 32# and now have they SVO 30#. They both worked great without any problems. I have a fairly aggressive setup too. The duty cycles with the 30#s in there are good.
I heard all kinds of bad things about the Accel injectors but didn't have any problems with them. However, if you are going to buy some injectors then I would say the SVO because everyone pretty much agrees on those being excellent injectors.
Old Oct 3, 2005 | 01:51 AM
pkincy's Avatar
I have 2 separate 383 LT1s (well one is an LT4) and they are fine with SVO 30s.
Duty cycles are below 80%.
Perry
