ed wright computer?
Old Sep 18, 2005 | 12:08 PM
ricknbird350's Avatar
Default ed wright computer?
i had my comp programmed by ed wright and put the new engine in and first off he programmed it for 24lb injectors instead of the 30lb i asked him to program it by but its also throwin codes like quad driver 1 fault and tps curcuit high and opti grounded. these are most of the codes. anyways i called him and told him about them and he said they arent comp related. and he wants 150 just to fix the injector size that he screwed up how rediculous is that? let me know what you all think has anyone ever had a opti grounded problem? what do i do to fix it?
Old Sep 18, 2005 | 02:03 PM
TwoFast4Lv's Avatar
Well he is right. Sounds like install error on the codes Fuses or wires and grounds are what I would check
Ed is usually pretty fair on stuff. They probably have the form you filled out to referance
Good luck
