cams
Old Sep 20, 2005 | 04:21 AM
riodealz28's Avatar
Default cams
i dont know that much about cams but which of this cams is just a lil bigger than the lt4 hot cam and is the cam good for top end like till 6400 rpm's and with stock heads only 1.6 rr and new springs
CC305
advertised dur 276/290
dur @ .050 220/230
lift w/1.6rockers .544/.544
lsa 114
XE503
advertised dur 276/281
dur @ .050 224/230
lift w/1.6rockers .536/.544
lsa 112
GM846
advertised dur 284/292
dur @ .050 222/230
lift w/1.6rockers .543/.563
lsa 112
Old Sep 20, 2005 | 06:41 AM
METALBEAST's Avatar
All of those cams are superior to the LT4 hot cam. Are you running stock unported heads? The CC305 is just a little bigger than the hot cam. Specs on the hotcam are
218/228 0.525/0.525 lift @ 0.05 inch lift w/ 1.6/1 rockers.
Old Sep 20, 2005 | 07:18 AM
JS_CZ28's Avatar
I would run a cam with a little more exhaust duration like a 224/236 or a 210/224. both of them have done excellent on stock heads and even hits 12s
Old Sep 20, 2005 | 09:16 AM
z28racerlt1's Avatar
I ran a cam only car for two years. The cam is a lunati hyd roller. 222/232 .471/.502 112 lobe sep. The car went 12.20 with stock trans. and 11.80 with a turbo 400 w/trans brake. I know the car had more in it because the 11.80 pass was at 2700 DA. There was still some tuning room also. I think the car could have went into the 11.50's Very streetable and still has a good sound. The only thing is I don't think it would pass emissions.
Ken
Old Sep 20, 2005 | 03:52 PM
riodealz28's Avatar
i have stock unported heads i think im going to live the heads stock so how much hp will the cc305 cam with new spring's and 1.6 rr give me with and without tunning ? o and with that cam will i get the kool cam sound that car acts like if its going to turn off but it dosent ?
