Next Step? LT1 Mods?
Old Sep 21, 2005 | 01:40 PM
edlt1's Avatar
Default Next Step? LT1 Mods?
I have a
96 Formula LT1
So far all I have done is the basics
3.73 rearend
Hypertech PP3
K/N air filiter
Off Road Y-pipe
Flowmaster Cat-back
Some Free Mods
52mm throttle body
TB Air Foil
LT-4 Knock Mod(Not sure if that made any difference)
And I am thinking about getting pulleys. Crank and Alt
WHAT NEXT?
Any advice would be great thanks!
Would fuel injectors be a good Idea with the Air flow I have created with the Y-pipe,flowmaster,52mm throttle body and removing the air grate in the intake Also possible Nitrous Kit in mind?
Old Sep 21, 2005 | 03:39 PM
luckyou03's Avatar
no, your not even close to needing higher flowing injectors yet.
I've heard nothing but bad things about these pulley kits for lt1's. They dim your lights, and give no power gains.
I go with some 1.6 RR, cai, nitrous and an electric cutout.
Old Sep 21, 2005 | 03:42 PM
sssalah's Avatar
Headers!
No need for injectors now, you'll need them with big cams/cubes. Get long tube headers now and after that 1.6 rockers.
Old Sep 21, 2005 | 03:46 PM
brandboZ28's Avatar
If your car is an A4, get a converter! By far the biggest gaining mod I did. I gained .7 in the 1/4 mile when I put my 3500 stall in.
Old Sep 21, 2005 | 04:55 PM
SlowBlueFormula's Avatar
That and converters are just waay too much fun to play with.
It's like...getting a whole new car there for awhile.
Old Sep 21, 2005 | 05:22 PM
DD97TA's Avatar
like mentioned above skip the pullies nothing but a pita! I would go with a set of pacesetter longtubes and a Cold Air Intake (CAI). Converter and nitrous is also a another good idea, but id go with longtubes before you do any of that.
Old Sep 21, 2005 | 06:52 PM
The LT1 That Could's Avatar
That air flow you created...is choked up more than a widow at a funeral. LT1s have horrid stock induction systems, replace that with a K&N or Moroso. That will benefit the 52mm TB. Stock Manifolds do nothing to help out that off-road y-pipe. and whatever airflow that has been pushed back that far, is choked off by the Blowmaster exhaust.
MOD IN THIS ORDER.....
CAI, LTs, Different Catback or Cutout. then get you a converter and spray the **** out of her. You may wanna upgrade the fuel system, mainly the fuel pump, at that point and time, otherwise wait until you hit about 375rw N/A before upgrading injectors.
Old Sep 21, 2005 | 07:18 PM
slowmofo's Avatar
Unchoke your intake first...then the exhaust, at least headers, pref LT's If your a a4 a converter is a Must, they are so much fun besides the performance gain..
Old Sep 22, 2005 | 02:28 PM
edlt1's Avatar
Default Exhaust?
Okay so as far as exhaust.
I have the flowmaster, which everyone is saying is not enought flow.
What are some better suggestions.
I Thought that the lest restricting exhaust such as Loudmouth or TSP rumbler is more for highway instead of 0 to 60 or 1/4 mile
Is this true or was I told wrong?
What about
Hooker
or tsp rumbler
I am not sure how great tsp rumbler will be driving though my quiet town at night time with the over population of shady blood sucking cops we have.
perhaps hooker with a cut-out?
Let me know
Thanks
Old Sep 22, 2005 | 05:45 PM
airflow is airflow...doesnt matter whether you r on the highway or the track, the more airflow the faster exhuast gaes will be pushed out.
hooker is nice and quiet when capped. run you a cutout for the track and u will be set.
also, just FYI, i have seen before a car lose 1rwhp going from open cutout to closed cutout with hooker catback. They are great flowing systems with looks and price to match.
TSP rumbler is just as good a catback, but is going to be louder than the Hooker. not annyoyingly loud, but it will definately be more noticeable.
Old Sep 22, 2005 | 09:56 PM
edlt1's Avatar
Default Headers
What type of headers
Short
mid
long.
Long will cause ground clearence problems right?
the y-pipe I have hooks up to shortys.
What would be the best choice,
Old Sep 22, 2005 | 10:36 PM
Bawls's Avatar
Short
mid
long.
Just to give you an idea, I have pacesetter longtubes and eibach prokit lowering springs. I have yet to hit anything on the ypipe or the headers. Trust us, get longtubes. You can find coated pacesetters with y pipe for around $450-500.
Old Sep 23, 2005 | 02:48 PM
edlt1's Avatar
Even if I live in Michigan. The road suck.
I guess I will make this a summer project.
Thanks
Old Sep 23, 2005 | 02:54 PM
DD97TA's Avatar
if you worry a lot about ground clearance just get the coated mid-length headers pacesetter offers and that comes with a ypipe... and add the hooker on it and your exhaust should be done. After that your going to want to guy a CAI and get your throttle body ported, hell you could port it yourself, i ported my throttle body and there was a noticable difference in throttle response
Old Sep 23, 2005 | 04:18 PM
Greenfire's Avatar
Short
mid
long.
I have a 97 Formula and I have the coated pacesetter LT's on the car and they are the best thing that I bought. They really opened the car up, I then did a cut out along with a Yank 3000 Stall. I had to get re-use to driving the car...it was really different. The headers may scrape if you go over a large speed bump but other then that they are fine.
Old Sep 23, 2005 | 04:19 PM
brandboZ28's Avatar
Whatever you do, DONT GET SHORTIES!!!!! Its not even worth the hassle of the install. Im running mids and getting ready to upgrade to LT's. If youre worried about clearance, get the mids.
Old Sep 23, 2005 | 04:23 PM
Greenfire's Avatar
Yeah you got that right! I have a crap master on mine, and with the LT's on the car and the cut out open my car is crazy loud!!! And its just a bolt on car...LOL!
Old Sep 23, 2005 | 06:10 PM
ditto, get ya some LTs, you won't be dissapointed.
Old Sep 23, 2005 | 09:24 PM
edlt1's Avatar
alright so some long tubes. Pacesetter.
Long tubes and Hooker cat back, perhaps with a cut out even though it sound like i may not need it.
I have a 2000 stall converter that I got when I rebuilt my trans. I believe is the a4 Its the 4 speed.
So after the long tubes and hooker
will I be ready for a cam?
Lt4 cam kit
or something better.
What other small mods would be easy to do at the same time as the cam?
Thanks again guys
your really helping me out a lot
Old Sep 23, 2005 | 09:29 PM
brandboZ28's Avatar
Get a higher stall converter and put a cam and valvetrain in it! Buy some sticky tires and hold on!
