pinion, and drive shaft angle
Old Oct 11, 2005 | 11:35 AM
chris77's Avatar
Default pinion, and drive shaft angle
i got the sphone adgustable tourqe arm that mounts to the chassis with the driveshaft safty loop, and was woundering what is the best angle for both the pinion, and driveshaft for street use, and my car is lowered dose that change anything
Old Oct 11, 2005 | 02:29 PM
chris77's Avatar
anyone.
Old Oct 11, 2005 | 04:22 PM
Mean.Green.TA's Avatar
I just installed the same setup (minus the driveshaft loop). Spohn recommends -1 to -2 degrees of TRUE pinion angle. If they are making the product and they are the testers/designers/etc I'll go with what they recommend. Lowering the car should NOT affect the goal of having -1 to -2 pinion angle. With that said, since your car is lowered do you have an adjustable panhard bar? If not, I'd imagine your rearend would not be aligned properly and the offset will probably be exaggerated by the torque arm when launching the car from a complete stop.
It's really easy to set the pinion angle. Did they supply a pinion angle finder?
Let me know if you have any questions.
- Jeff
