how much RWHP can you get with LT1
Money is the only thing stopping you pimp, HPE (Home of the world's baddest LT1) has a "Big Boy" engine package. It is a duplicate of Big Ricks setup, minus the turbo but motor wise they offer any CR you want, I think it starts out at like 5k-7k. If you are on a smaller scale budget a built 396 NA you should be able to get 450+rwhp. A good set of heads and a good cam will be necessary.
Originally Posted by Turbo_6
I'm at 472rwhp/424rwtq currently. I am having opti issues above 6500rpm but will probably pick up a few more after this is resolved.
Originally Posted by Bizzzatch350
How much money do you have, Ricks LT1 made 1238rwhp on a 91.5 mm Turbo.
i made 691 rwhp but that was through a TH400, 4800 stall (non lockup ofcourse), steel driveshaft for drag racing, Moser rear with 4.11 gear, and 28" m/t drag tire at 15 psi of pressure. its easily 850 hp at the motor.
no nitrous, street car 100%
Vortech YSi 383LT1 motor.
nothing special about my motor. in fact, the motor is pretty much a budget buildup!
Internet Mechanic
If gas and emissions are no concern, then the sky is the limits, you need to set your terms, I know you want 600-700 rwhp, but there limiting factors.
Gas
Emissions
Driveability
Most of these things at that power range become a moot point, but I am looking at high 500's through a emission passable setup and a auto with 2500 stall, 3" steel ds and moser 12 bolt
Gas
Emissions
Driveability
The motor is a Lunati crank/rods, Diamond pistons, N/A 383 w/ AFR 220cc heads and comp solid roller. We've got a few bugs to work out of the setup and we're hoping for around 485-490rwhp when it is all said and done. This is through hooker 1 3/4 longtubes, LT4 intake, and stock computer, 93octane. Building a 500rwhp is definitely possible if you plan ahead and take your time matching the appropriate parts. There's obviously some tricks to building these motors and getting the extra HP as well. If you drove this car, other than the distinct solid roller sound, it idles, cruises, and drives really good. Makes power to 7000rpm and over 400 rwtq at 4000rpm and above.
Geaux Tigers!
Geaux Tigers!
Originally Posted by lt1fbody355
sure if you build it right and then added some NAAAAAAWWWWWZZZZ!
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
It has been judged that you should be taken out and whipped with a fuel return line for uttering that silly ricer term!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Gay!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_rainbow.gif)
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
![Thumbsdown](https://ls1tech.com/forums/images/smilies2/thumbsdown.gif)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
Besides that I just wanted to use a bunch of smilies
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
i have a very similar motor to his and it cost well over twice that.
brook
I think you need to be slaped with a NAAAAAAWWWWWWZZZ line.
