58mm throttle body
And the blades open normal,idle is fine..no bog if anything the car jumps too much off the line now but that might be as have my tps at around .78 and think its should be more like .50 to .65 or so.I will be tweaking the tps shortly ,its simple to do.
With an A4 car a TB requires programming unless you want to blow up the tranny, the more power it will give at less throttle can cause issues because tranny functions at TPS scaled this is even when the TB results in no gain of overall power as it would in a stock car. 10% throttle angle with a 58mm is a whole lot more air than it was at that same percent with a 48mm.
The reason is the trans shifts based on tps%,and since you'll get the same air at a lower throttle opening with a bigger tb, you get slower, sloppier shifts. It can kill the transmission.
This is even noticeable with a 52mm, but not as bad.
Looking at your mods I see a Granatelli which tells me you buy first and research later though so maybe that is the source of your mistaken info.
My 383" makes 508 at the wheels, through an unlocked 4400 rpm converter and 4.30 gears in a 12 bolt Moser, and it gained nothing. Unlike too much carburetor on an older car, a too-big tb won't slow you down, just cost money for no gain. If you have a 4L60E trans, like the others said, you will need the line pressure tables in the PCM shifted to maintain part throttle line pressure. Otherwise, good by clutches.Good luck, Ed
Good luck, Ed
The stock intake openings are 54mm.
Good luck, Ed
Good luck, Ed
im curious to know what should he spend his money on because im sort of in the same boat. i have my lt1 a4 bored out to 355, full exhaust, K&n fipk, trick flow intake elbow, msd ignition and no cats? im trying to go for an all motor car so what should my next upgrade be?
