How fast is your CAM only LT1?
Nice. Those are that same numbers I got out of mine before heads
, so here they are: Exuse #1, had to shift at 5500rpms since I have a bad miss at ~5800-6000 (opti). Exuse #2, second time ever to the track w/ the 6spd, but managed a 2.15 60' on the 13.3 run. Exuse #3, 80 degrees and very humid in this Florida weather. Exuse #4, was on street tires (245/50/16)Vid of 2 of my runs: http://www.crazyz28.net/Videos/Crazy...day.Sunday.wmv
I'm hopin by January or February I should have a new opti and some borrowed DR's, so 12's should be reachable, right?
EDIT: Mods are XE 230/236, stock heads, Mac mid-length headers and cutout, CAI, tuned by myself w/ 12.8:1 A/F, and 3.73s.
Ain't that right Matt...????
So if i were to run LT4 conversion and forced induction of some type (probly turbo)... what kinda times could i expect? I mean, not so much boost that it aint drivable everyday... But some.
Nobody is going 12s with JUST a cam, stall, gears, headers, catback, coldair system are all necessary.
I put my Caprice together backwards I did the cam and went a best of 14.9, then the stall and went 14.1, then gears and got 13.9 with sticky tires, now I have headers and went 13.6 on street tires and 13.2 on stickies still full weight. If the weather cooperates I believe I can coax a 12 out of it still full weight. See above and my cam/stall/gears are all very mild, the headers pulled it all together and let it work right because it is the system not the parts that matter. You drop a HOT cam and LT4 heads on your car without all the periferals and I guarantee you my whale of a car will still be faster.
I may get a turbo kit (or s/c... depends on what i find out on the pair), good heads, and cam. I will follow up with stall and gears (posi). I ultimatly want to run 8.5:1 compression with forged rotating assembly and boost the **** out of it. But forged rotating assembly and rebuild is kinda pricy when tagged along with heads and forced induction.
First thing im buying for the car is suspension parts anyways. But i would like to plan ahead.
