How fast is your CAM only LT1?
Old Nov 11, 2005 | 09:56 AM
  #61
qcworm's Avatar
last night my first time out M6 i did this but i have no cam but full bolt on
it ran
5.77
8.744
83.48
5.74
8.722
83.51
Old Nov 11, 2005 | 10:17 AM
  #62
TwoFast4Lv's Avatar
Originally Posted by 96capricemgr
Stock f-body heads are aluminum and NOT superior to the irons matter of fact MOST of the LT1 aluminums flow less than all the irons with only the best aluminums equalling the irons flow. In now way saying swap to the irons just saying the "aluminum is better" thing is old and hard to stamp out ignorance. LT4 parts are talked about like the best things ever BY NEWBIES and magazines, those of us who have been around awhile try to keep this stuff in check but it is hard.
Actually IMHO the aluminum head DOES have better atributes from be modified then the Iron heads My Aluminum heads are now sitting at 210cc on the intakes ports and flow very well
Tha aluminum heads have some very nice benifits. Now take in mind I have been playing with LTx engines for over ten years now.
as with any aluminum head you get to run More CR then Iron all things being equal. The wiegh less and every pound counts. Have have a better potential for modification then the iron heads, most times you grind through a wal on iron heads you are starting over. With aluminum you just weld it up
I do agree the LT4 stuff is over rated. Unless you are going big Cubes and Big HP. Then you still need a highly modified intake to feed it.
when my engine was bone stock with only a Flowmaster muffler I bolted on an ATI kit and ran 12.6s consistant. I went 12 rounds one day with a 12.61 dial this was at 9Psi and no tuning. then again we did not have tuning tools back then
Best bang for the buck parts are ported stock heads and a hot cam kit with headers and a CAI.this can all be done for just over $2,000 if you do your own work
IF you are going to add a blower pull the engine and put forged pistons in it now with the age of the cars now it is just the wise thing to do. good pistons and a custom cam with supporting valve train into decent headers and a daily driven 11 second car will be your.
Good luck!
Old Nov 11, 2005 | 08:28 PM
  #63
96capricemgr's Avatar
The aluminums do have advantages they are just not magically superior as most seem to believe and most site the one major DISADVANTAGE as an advanatage I just want people to understand what is going on rather than keep believing a bad thing is good( the heat disapation is wasted energy period not that the compression and weight reduction can't overcome it). I am actually working on getting a set of aluminums for my car but that is because my porter of choice has not done any R&D on the irons largely due the IGNORANCE that surrounds them and the resulting lack of demand. As far as 210 ports on LT1 casting at that point might as well use the LT4s also I think most would agree that too large a port for a 350 would be great for a stroker though especially if looking to spin past 6K.
All goes well and sunday I will crack into the 12s in a full weight b-body with just a cam,rockers, and springs in the motor and with mild 2800/3.42 so I am not doing too bad myself even if I have only 5 years of LT1 research and play under my belt.
The irons are so bad that another b-body just broke into the 10s with ported iron heads a cam and spray on a stock bottomend. http://dan.esteban.com/impalass/ReturnTopET.asp see number 13 and 15 same guy same car just the SLOWER run is with the stroker with AFR LT4s. Not saying the irons are better or the best or anything just think they deserve substantially more credit than they get. We are very lucky a few of the b-body guys maintain such a page for us it is a great research tool anything similar for f-bodies? My current bests times are at down at position 141 and as noted I think I can get more out of it.
Old Nov 11, 2005 | 08:35 PM
  #64
TwoFast4Lv's Avatar
Well it is not that they are bad head. The question for most of us is why take the penalties for the same performance
Old Nov 12, 2005 | 02:10 AM
  #65
Dragframe's Avatar
Well the plan was something like this.
The motor in the car im starting with has literly... 20 miles on it. It is brand new.
So im going to run it untill the three year warrenty is out.
Then im pulling the motor. I will go with a full forged bottom end running about 8.5:1 compression with LT4 heads and intake. Don't forget the gapless rings. Cam will be whatever the cam manufacturer suggests. The heads will be flow benched with all the ports matching. Then some sort of supercharging or turbo. I think with 8.5:1 compression i could get away with 15 psi lbs. That should make for a real stout motor making AWESOME POWER. What you guys think im looking at for power?
Old Nov 12, 2005 | 02:41 AM
  #66
whynot's Avatar
it's going to be a little harder to get 8.5:1 with 54cc lt4 heads, your better off getting after market heads. but I don't see why you won't be pushing 700 + bhp.
Old Nov 12, 2005 | 08:36 AM
  #67
AGAIN not suggesting you guys swap to them just saying give them the respect due.
Old Nov 12, 2005 | 08:51 PM
  #68
AnthonyConstant's Avatar
so your saying a cam on a stock z will put you in the 12s?
Old Nov 12, 2005 | 09:16 PM
  #69
GIZMO's Avatar
In order for a "cam only" combination to run well you have to do a lot of work. You can run in the twelves without the cam if you work on everything else. My Firebird (LT1) ran 11.30's "cam only", but that only tells part of the story.
Daren
Old Nov 12, 2005 | 09:28 PM
  #70
A page or two back I believe I detailed the way I did things in the wrong order, cam only my best was 14.9 the car has since gone 13.2on slicks 13.6 on street tires and tomorrow I seek to better that, My gears and stall are very mild too at 3.42 and 2800, more gear and stall would certainly be daily driver tolerable this setup was aimed at 20K+ a year with "family" roadtrips to the east coast in mind.
There are several bolton b-bodies in the 12s lightening bigger stalls more gear, one even has a shot at 11s NA if he gets the right weather that car is often trailer to the track though were tomorrow I will be driving 120miles each way to run full weight and then maybe shed a few pounds. You just have to keep the details in mind when comparing setups.
Also I am getting 13.2 at just 101mph this chassis and the 28X10.50 ET drags I am running allow me to pretty fully use the torque I am making most other cars at this ET will be going a higher mph.
Old Sep 20, 2008 | 09:50 PM
  #71
2badz28's's Avatar
I have a 97 z28 with a .530 cc LT's. True duals 2500 stall 52mm throtle body RR's ported stock heads lt4 km 100 homemade wet shot with mickey et streets my best time is 1.52 60' 6.72 1/8
Old Sep 21, 2008 | 08:56 AM
  #72
305 h.o.'s Avatar
14.3@98mph just 4.10's and bullet muffler.
No new times yet but I added NGK plugs, 160 thermostat and 1.6rr's fells a good bit stronger.
Old Sep 21, 2008 | 12:02 PM
  #73
AChotrod's Avatar
12.40s @ 111 cammed, 11.20 @ 120 with 125 shot.
Old Sep 21, 2008 | 12:35 PM
  #74
robsquikz28's Avatar
12.29 with cam only
Old Sep 21, 2008 | 01:15 PM
  #75
StealthFormula's Avatar
damn talk about grave digging from 3 years ago. Lower 12's at 110-111 with cc503, 3600 Stall and full weight.
Old Sep 21, 2008 | 07:54 PM
  #76
Fast93Z's Avatar
Originally Posted by blind527
I don't have a cam and I got 8.7@83 in the 1/8.
same here man are cars are quick i had headers only and a burned plug wire with bald tires and i ran an 8.9 at 86
no bull **** if i find my time slip ill post it
Old Sep 21, 2008 | 08:02 PM
  #77
Saladbar's Avatar
Fastest I ran w/ a 224/236 Comp Cam and stock heads... 12.36@114mph. A +.030 bore and ported heads didn't help much. I only ran an 11.9@117w/ that.
A long long time ago...
Old Sep 21, 2008 | 08:43 PM
  #78
AF cop's Avatar
My car wet 13.30 at 105 mph as delivered from GM.
It went 13.001 at 106mph with 4.10s.
It went 12.89 at 111mph with hotcam and gears only, no tune, street tires.
It went 12.38 at 115 with drag radials, headers, and mail order tune added to the above.
The best 1/8th so far has been 7.87 at 90mph with a 1.76 60'.
If I could get it to 60 foot it'll go high 11s. 100k miles and the heads have never been off the car...but they are the over-rated LT4 heads though
Its had this cam for over 30k miles and get driven regularly. It still gets 25mpg hwy
