What plugs RU running?
Old Oct 19, 2005 | 06:01 PM
ecshaker's Avatar
Default What plugs RU running?
Getting ready to put my new motor in and trying to pick plugs I ran NGk TR55's in my last motor just trying to see what the masses are using. Thanks
Old Oct 19, 2005 | 06:02 PM
BBADWS6's Avatar
TR5's, or TR55's, or TR6 for nitrous
NGK is the ****
Old Oct 19, 2005 | 06:55 PM
96capricemgr's Avatar
I have run TR55s TR5s regapped to .050 and Autolite 104s all with decent results.
Old Oct 19, 2005 | 07:00 PM
ecshaker's Avatar
Would yall still runnin the TR55's with a 75 shot?
Old Oct 19, 2005 | 07:10 PM
Wicked_Hugger99's Avatar
TR55s here. My buddy who used to own the car ran TR6s when he had spray on it, 100 shot dry
Old Oct 19, 2005 | 07:47 PM
brandboZ28's Avatar
Im using Autolite 104's right now but I might step back to a slightly hotter plug to see if theres a difference. TR-55's have always performed great in the past so I might go back to ole reliable. My car is NA btw, no NAWS.
Old Oct 19, 2005 | 07:49 PM
foggedz's Avatar
NGK BR7EF..... best plug for spray
Old Oct 19, 2005 | 07:56 PM
transamtom's Avatar
NGK TR55's.
Old Oct 20, 2005 | 10:24 AM
dhdenney's Avatar
Another vote for Autolite 104's. I think 106 is stock heat range, 104 being one colder (for nitrous). Autolites are half the price of NGK's and you can get them at Wal-Mart. NGK's aren't available everywhere,
Old Oct 20, 2005 | 10:43 AM
Chris 96 WS6's Avatar
TR55's here.
Old Oct 20, 2005 | 10:59 AM
stevemilz's Avatar
Ngk Tr6
Old Oct 20, 2005 | 11:43 AM
GreenbeanZ28's Avatar
Autolite 104's.
Old Oct 20, 2005 | 12:39 PM
ks my ss's Avatar
ac delco r44lts
Old Oct 20, 2005 | 01:33 PM
rebersole2's Avatar
Autolite 104's here. Bought 4 twin packs at Walmart last night, @ $2.18 each (per twin pack).
Old Oct 20, 2005 | 01:40 PM
BlazerINtheWork's Avatar
i have some Ngk Tr6's, everyone always suggest them for spray applications
Old Oct 20, 2005 | 03:47 PM
quick93transam's Avatar
believe it or not i run the Bosch +4s. i see a lot of people talk bad about the bosch for our engine but i have had no problems at all. i plan on trying the NGKs next so i have something to compare to.
Old Oct 20, 2005 | 09:05 PM
97SprChrgd383's Avatar
What about with a supercharger? What does everyone recommend?
Old Oct 20, 2005 | 10:07 PM
you are prolly one of the only people i have ever seen that has not had trouble with bosch.
Old Oct 20, 2005 | 11:39 PM
dhdenney's Avatar
Platinum + nitrous = bad. Besides, a spark is a spark. I'd rather spark for a $1.09 rather than $7.09.
Old Oct 21, 2005 | 08:11 AM
I did run the r44lts for awhile only downside was getting ahold of them.
The Autolite 106 is supposed to be the stock heat range but at least with the iron heads they prove a little too hot this may be due to the different thermal properties of iron vs. aluminum. Many of the iron head guys spraying go to the 103 with the NA guys running the 104.
Platinum offers just one advantage and that is resistance to gap wear there is no performance advantage and as already noted it is BAD for spray or boost. Multiple electrodes are a SALES GIMICK. Spark will take the ONE path of least resistance leaving the other electrodes to get fouled. On another forum I frequent one guys wife as an engineer at GM and one of the projects she had worked on was testing multiple electrode plugs because OEMs would be all over it if it had any genuine advantages. Well she found nothing positive about them and as a result bet you can't find a single car that comes from the dealer with multiple electrode plugs. The side position of the Bosch multiple electrodes might be of some advantage if there were only one as it might allow better flame travel but the 2-4 they put in there negates that possible benifit. Some marine plugs and what my brother runs in his gokart are gapless and he actually did pick up a small amount of laptime like that. Beliee those sorts of plugs foul out fairly quickly though hence their lack of use in automotive engines.
