fuel check valve?
Old Oct 23, 2005 | 08:17 AM
ricknbird350's Avatar
Default fuel check valve?
does anyone know where the check valve is located at??? i replaced the pump and it still drops fuel pressure when it primes..
Old Oct 23, 2005 | 10:55 AM
Low N Slow's Avatar
The check valve is in the fuel pump, if it still drops pressure after a new pump you may have a leaky injector. What kind of fuel pump did you install? I recently replaced mine and had the same problem and ended up finding several very small holes in the teflon line the attaches the fuel pump to the metel lines that run out of the tank.
Old Oct 23, 2005 | 04:10 PM
i put a walbro 255lph in..i replaced all the injectors..i cant figure it out
Old Oct 23, 2005 | 06:41 PM
SmokedOutZ28's Avatar
regulator maybe?
Old Oct 23, 2005 | 07:18 PM
nope its got a new aeromotive one...
Old Oct 23, 2005 | 07:34 PM
ok how bout gas cap? gasket doesnt seal pressure bleeds off thats the problem i had after installing my racetronix unit... or maybe the gasket from the sending unit is leaking.
Old Oct 24, 2005 | 12:09 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
- regulator
- injector
- fuel feedline
- pump checkvalve
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
