is this normal?
Old Oct 26, 2005 | 11:33 AM
95transamguy's Avatar
Default is this normal?
i just got my 3500 stall and shift kit put in and broke it in. i went out this morning and got on it a little bit and it shifted fine into 2nd, but when it was going into 3rd, it tapped the rev limiter a couple of times. is this because the tranny wasnt rebuilt right or because now i need a tune because of the converter to reset my shift points.
Old Oct 26, 2005 | 12:27 PM
bump! i need to know
Old Oct 26, 2005 | 12:31 PM
97MysticZ's Avatar
What's a Sticky?
I dont know much at all about stall converters, but I'm thinking its normal, probably until you get a tune. The reason I say this is because I've watched two videos of cars with stalls and they both tapped the rev limiter. Sorry I couldn't be more help.
Old Oct 26, 2005 | 12:47 PM
blkchevyz's Avatar
i'd check the fluid but alot of people have an issue with 3000+ stalls on obd1 cars.
useally need some programming to get rid of that
Old Oct 26, 2005 | 11:44 PM
good thats better than having to take it back to the tranny shop. thanks for the help
Old Oct 27, 2005 | 12:20 AM
buffman's Avatar
yeah and I had no luck with the tuning I received for my high stall on my 95. For some reason my car didn't lke it and would quickshift from 1st to 2nd way far away from shiftpoints. Even if I dead hooked it did it. So I took a chance and had bryan herter remove it. Car runs good now
