lt1 problems
Old Oct 28, 2005 | 09:17 AM
96z28's Avatar
Default lt1 problems
i have a 96 z28 when i got about 3 months ago it ran fine but since started running 89 octane since thats all thats aviable in my area the car will miss or shudder severaly under a load at rpms of about 1200-2500. about 2 weeks ago i tried 91 octane and the car quit missing and ran great, then i went back to 89 and it runs even worse now.
if any one has any ideas i would greately appreciate it.
Old Oct 28, 2005 | 09:47 AM
blkchevyz's Avatar
your suppose to run premium in these cars.
Old Oct 28, 2005 | 10:45 AM
LukePhillips's Avatar
In Need of Cup Holders!
If the car run runs funny with 89, but fine with 91, I think youve found the problem. I personally use 93 every time, it also says you should use premium on the gas flap. Yes it costs more, but youre driving a Trans Am here. This aint no Honda.
Old Oct 28, 2005 | 03:13 PM
94strokedz's Avatar
10.8 compression, 89 will not fire properly! If you wanna be able to run that gas, youll have to lower your compression.
Old Oct 28, 2005 | 08:04 PM
VanbibberLt1's Avatar
i ran 89 one time. ran like ****. never again,never again.
Old Oct 28, 2005 | 08:47 PM
96z28's Avatar
the owners manual recomends premium but says that it will run on less octane gas,and also my sisters a 1996 black Z28 auto runs just fine on 89 and it has 130,000 miles, does any one have any other opinions other than just to run 91 because where i live the only gas aviably is 85 and 89 octane unless i drive 80 miles.
Old Oct 28, 2005 | 09:00 PM
infinitebird's Avatar
It also says that "your vehicle may not accelerate as well" if you do that.
Basically that means if you hit it hard it will miss and not run well.
There's really no other fix other than to run better gas or not get on it hard.
Old Oct 29, 2005 | 11:11 AM
slowpoke96z28's Avatar
the manual states that for people that want to use cheaper fuel to know they can't expect maximum performance. THEORETICALLY, a STOCK LT1 can run 87 all day aslong as the knock retard system works with no damge to the engine, but it will definitely feel slow. best advice is to stay at or below 70% throttle and the car shouldn't detonate. also consider moving to a place where ther is more than 2 octane choices, or get a cavalier or something like that to dailydrive and only drive this car for fun, and keep high octane in it.
Old Oct 29, 2005 | 11:19 AM
flatlander757's Avatar
Um, it's MAYBE $1.50 more per fill up... it's not that bad. Get premium.
Old Oct 29, 2005 | 11:41 AM
Speed Density's Avatar
hashtagBMW
Default .......
87..........2.50 89............2.60 91..............2.90-300, if you cant afford to spend the extra change sell ur car and buy a beater, i hear geo metros get great MPG, but no SPG (smiles per gallon).
Old Oct 29, 2005 | 12:25 PM
guys keep in mind it will take him 1/2 tank round trip to get that premium octane. lets not him too hard. BTW, where do you live? maybe you need to buy fuel by the 55 gallon drum and get it delivered to your house.
Old Oct 29, 2005 | 12:37 PM
I like that metric.
Old Oct 29, 2005 | 02:14 PM
slowmofo's Avatar
damn that sucks you can only get 89..... buy some octane boost? I have never tried that **** but it might work.
Old Oct 29, 2005 | 02:16 PM
thunder95ta's Avatar
Default low octane gas
I know what you mean i can only buy 89 ocane in my area as well. All i use to run was supreme in the tank. Sucks hard having to put lower grade fuel in, Does anyone kknow if octane booster will help at all?
Old Oct 29, 2005 | 10:03 PM
carzman5678's Avatar
I like to think of this. I have a 91 RS and now a Z28. Gas costs more, but "You gotta pay to play"....
Old Oct 30, 2005 | 08:24 AM
mightyquickz28's Avatar
Sounds like you want athletic performace on a Ramen Noodle only diet. You can't get there from here.....
The only thing I've found in the "Octane Boost Can" usage is increased fouling of my plugs. Orange crap all over the insulator/plug tip.
There's a Buick G/N site that lists a method of mixing Xylene or Toluene with gas to raise the Octane level but some guys have reported that use of these chemicals can harm the plastics in our Fbody fuel systems. Aside from that, even if you purchase these chemicals by the gallon at most paint stores (Sherwin Williams, etc) the increased costs can diminish your enthusiasm for this potential solution.
Read here to get "first person" info on this.
http://www.turbobuicks.com/forums/sh...ad.php?t=39482
