Long tubes
Old Oct 31, 2005 | 11:07 AM
Quick96ss's Avatar
Default Long tubes
How hard is it to install long tube headers i am looking at getting eather the kooks or the stainless steel works. I have heard i have to lift the motor is this true? When i do these headers i am doing heads and i am doing a clutch so the tranny and bell housing will be off. Any help would be great. Which headers and y-pipe are better kooks or stainless steel works?
Thanks
Old Oct 31, 2005 | 11:12 AM
Nick213's Avatar
When i installed mine this spring i had to unbolt the steering knuckle on the drivers side, and on the passanger side i had to undo the mount ant lift it about an inch or two to get it to slide in right. if your doing it without a lift try to get the car as high off the ground as possible it will make life alot easier.
Old Oct 31, 2005 | 01:25 PM
firebird6786's Avatar
go with the Kooks. there the best header ive seen. QTP is right along with them. cant beat the detail in welds and airflow tube design!
Old Oct 31, 2005 | 01:35 PM
Quick96ss's Avatar
i can get the stainless works for 854 that is for the headers and y pipe. Do you think i should do it or should i just save more and buy the kooks?
Old Oct 31, 2005 | 02:00 PM
1bottled93toenvy's Avatar
u alwyas get what u pay for....go with kooks....when we did my headers we had my car way off the ground and it was still a bitch. there are alyas going to be thign that come up u may break things...but best to get that car as high up as possible....just be careful when getting it too high...and also dont try and rush it and get it done in 2 hours so u can go out that night...take ur time just my .02
Old Oct 31, 2005 | 09:36 PM
FlamingChicken's Avatar
I put Kooks on my car early this summer. The hardest part was getting the old stuff out. Damn rusted bolts. Cutting it out was a lot easier. I love my headers too. You do have to raise the engine but its not near as hard as it sounds. just loosen the motor mount or unbolt it, depending on how much room you need and then jack the engine up with a block of wood. If you want you can also drop the engine and tranny together. would make it all a lot easier especially with the clutch and heads. Have fun
Old Oct 31, 2005 | 10:25 PM
Quick96ss's Avatar
Flamingchicken, did you notice a big difference with those kooks headers?
Old Oct 31, 2005 | 10:26 PM
97blkz's Avatar
It will depend on your mechanical apptitude! I personally suck and it kicked my ***!
 Michael S. Palmer
Old Nov 2, 2005 | 10:49 AM
Quick96ss's Avatar
do i have to use o2 sims? if i put longtube headers on or do i just get extensions for the o2 sensors and hook them back up?
Old Nov 2, 2005 | 11:01 AM
Nick213's Avatar
Id go with the extensions, i got mine from thunder racing but summit carries them as well.
Old Nov 2, 2005 | 11:11 AM
Quick96ss's Avatar
so are the o2 sims only used for ls1 or what i dont understand if i should use them or not?
Old Nov 2, 2005 | 02:54 PM
when u order the headers from kooks u need to get the band clamps for the y pipe, O2 extensions and you need to find caps or crapy O2s to cap the O2 bungs in the Y pipe. if your tunning the car take the O2s out of the header bungs and put them in the y pipe bungs and cap the header bungs.
Old Nov 2, 2005 | 03:07 PM
Quick96ss's Avatar
Why do you do that? So i shouldnt run o2 sims just the o2 sensors on extesions. Why do i buy clamps just from kooks?
