I need specs
Single spring with 1.32" O.D. and 1.22" solid height. The pressure at installed height IS 101# @ 1.78" with 332# the average rate of pounds per inch. Use with retainer P/N 10168424.
with that I would assume that the spring height is 1.22"
seat pressure is 101# @ 1.78"
open pressure ? @ ?
coil bind ?
average spring rate is 332#
and maximum net lift, ?
and why if this spring is good on the hot cam exhaust, I belive it is 218 @ .050 with max lift of .525.
why would it not be good on a similar cam, with the same or less lift, and the same or less duration?
All I will say is mine was done right the first time, which includes a little boost (15 psi on pump gas) from a t70 for the street.
the springs are some that I have laying around that had less than 3000 miles on them and a friend is wanting to do a small cam for the spray, although I have tried to convince him other wise. but for now he wants to go cheap, since I already have the springs and all to go with to give him and he is picking up a cam cheap.
