glowing header tubes
Old Nov 5, 2005 | 05:53 PM
1BadAsZ's Avatar
Unhappy glowing header tubes
ok i had a terrible miss...to the point where the car would bout cut off when you try to take off....saw some of my plug wires arcing and so i figured it was time to change em. i took all of the old plug wires off and 2 of them were burned really bad. so i swapped out plugs and put some taylor wires and heat shields on. i was holding the throttle at about 2500 to see if there was anymore arcing and now i have a few header tubes glowing...what do i do next?
Old Nov 5, 2005 | 07:42 PM
Vendetta's Avatar
glowing primaries are sometimes indicative of a misfire, you may still be having problems.
Old Nov 7, 2005 | 03:26 PM
LWillmann's Avatar
My header tubes would start to glow if I held the throttle to 2500 for a time too.
Replacing the plugs and wires helped considerably.
Old Nov 7, 2005 | 05:34 PM
jester1's Avatar
if it is not running extreamly rich scan and check timing. its probably not advancing and running very retarded
we chased our tale once
