Side exhaust
Old Nov 9, 2005 | 12:48 AM
Quick96ss's Avatar
Default Side exhaust
Has anybody ever seen or done a side exhaust exit? Like right infont of the rear wheel is this possible? I think it would be a bad *** set up.
Old Nov 9, 2005 | 12:56 AM
omaha stylee's Avatar
i have seen it done...... on a 97 formula with ovaled pipes......... it looks good
Old Nov 9, 2005 | 06:57 AM
sparky t/a's Avatar
boomtubes.
Old Nov 9, 2005 | 10:56 AM
Quick96ss's Avatar
so how would i do it? Could i still run long tubes? Does anyone have any pics?
Old Nov 9, 2005 | 12:01 PM
dhdenney's Avatar
I would take a look under a Roush Mustang with side exhaust to see how they did it. Otherwise, you'd just bend your pipe over to where you wanted it to exit.
Old Nov 9, 2005 | 12:28 PM
Quick96ss's Avatar
it would take some work fitting longtubes and the y pipe and a muffler cause i want it to be streetable. I will have to think about it and do some reasearch. Any other help would be great.
Old Nov 9, 2005 | 01:18 PM
pigpen's Avatar
I think a y-pipe setup would be more trouble than it would be worth. It's not to difficult to do LT's, duals, and side exit (even with 3").
Here's a link to my install (bottom pic is not my car):
http://www.cardomain.com/ride/199561/4
If I had to do it over though, I'd have made a few changes.
I'd probably run with no cats, although they were not very difficult to clear - just few taps on the floor pan to tuck them.
The car-chemistry insert mufflers are more restrictive that I thought. I'd use bullets or something similar with a straight through design, and get rid of the cut outs. The cutout flanges where the hardest thing to clear and are are still the lowest point of the exhaust. I'd run an x or an h pipe - without either of those, side exit dual setups tend to make kind of a chugging sound at some rpms, when you're only hearing one side.
here's some pics of the car - it's hard to see the exhaust though. If you enlarge some of the pics you can see them a little. I ovaled the aluminized tips to tuck them close to the body - I wanted a subdued look, which I think I got, instead of bright shinny tips. To each his own though...
http://www.cardomain.com/ride/201570
Old Nov 9, 2005 | 09:13 PM
sparky t/a's Avatar
www.drgas.com
Old Nov 9, 2005 | 11:20 PM
Quick96ss's Avatar
Originally Posted by sparky t/a
That site is what i am looking for i am calling them. I wonder if that would fit under my car? or hang in the right spot? Thanks for the help
Old Nov 10, 2005 | 12:07 AM
Quick96ss's Avatar
has anybody ever ran the elanore side exhaust? That is what i am thinking of buying.
